HowTo Re-establish Rib Curve?
I'm sure that I'm not the FIRST novice builder to straighten the first inch of the rib from the leading edge back. Honest officer, I was just sitting there with a sanding block in my hand and BLAM - there was a brilliant flash of light. When I could see again the ribs were straight! I swear - I didn't do a thing.
OK, damage is done.
The wing is a 4Star60. The damage is between the leading edge and the 1st of 2 forward spars (3/16). I messed up 4 ribs.
Oh great peanut gallery - lay your corrective suggestions on me.
Many thanks,
OK, damage is done.
Many thanks,
RE: HowTo Re-establish Rib Curve?
1. Sand the compromised area flat between the LE and the forward spar.
2. Fab pieces of balsa from scrap using the plans with the correct curve and the straight edge per step 1.
3. CA the pieces on.
4. DON'T sand 'em flat again.
Did I get it right?
Thanks very much.
Did I get it right?
Thanks very much.
What I did:
1. sand the problem ribs flat
2. glue balsa stick of same thickness - pic 1
3. fabricate a template for the proper profile - pic 2
4. transfer profile to rib - pic 3
5. sand the rib to the new profile - pic 4
Thanks for the help.
w8ye - I use a fairly long sanding block myself - I just wasn't paying enough attention when I was rounding the leading edge to match the ribs.
I have done that many times, and I've used the same remedy.[sm=red_smile.gif] Your repair job looks great. FWIW, the plane would still fly fine, it would just look a bit odd. On models without forward sheeting the shrunken covering cups between the ribs anyway, dipping below the ribs' airfoil.
David
David
This is what my 1st 4*60 looked like covered. I understand what you're saying about covering and "open" covering between the LE and the main spar.
Been there, done that, got the T-shirt.
Glue 1/8" X 1/8" strips (or whatever the rib thickness) strips over the edges of the ribs and start again.
I get them to shape as a group and then once on the spars use a 24" sanding block with fine grit for the final smoothing.
Charlie - about the stack of ribs in your photo - are those scratch-built ribs? Reason I'm asking - I have a wingless Sea Dancer. I have the plans for the wing & engine nacelle. Some time I will attack that challenge - just looking for information to squirrel away until then.
