Goldberg Ultimate (kit) Landing gear?
Who makes gear for this plane or perhaps something from greatplanes (or other main stream vendor) that will work with the goldberg ultimate. I'll be running a os 1.20ax and need clearance for 16-17" props...
thanks
thanks
My Feedback: (9)
RE: Goldberg Ultimate (kit) Landing gear?
I have the ARF. It is a drop but if Tower still has some of the gear it is a nice alum piece. Or you could try this.http://www.rcwings.com/index.php?mai...oducts_id=2717
David
David
Thanks! Do you know the part number of the gear that came with your arf? The goldberg manual doesn't show the part number.
NY
Hi Tom,
I'm Ken of 'hobbyncrafts'. I've been making custom CF landing gear for well over 10 yrs. I have made gear for the ARF version of the Ultimate in the past. The dimensions for that gear were as follows: 5.5" across base of fuse, 14.5" span at wheelbase, and 5.5" in elevation from axle line to fuse. I could make this, or, another with dimensions you require.
You can contact me direct at: [email protected]
Ken
Ken
