Coverite Silkspun
BC,
Coverite Silkspun
I'm new to the game of building and was wondering if Coverite Silkspun was any good for covering gliders and slow movers?
I happened to come across some for sale....
AZ
Coverite Silkspun
I used this several times back in 1977 with paint over it. It is tough and pretty stable once it is on. I didn't think it was all that light. I don't think it has been available for quite a few years. I think transparent Monokote or Ultracote would be a better choice for gliders or anything you need to keep the weight down on.
Clair Sieverling
Clair Sieverling
BC, CANADA
Coverite Silkspun
Many built up gliders require the strength of Monokote, as it becomes an integral part of the structure. Silkspun coverite will not have that same strength. I use silkspun coverite on planes where the fuselage or wings are fully sheeted with balsa. The silkspun does a great job filling in the grain and providing a great base for a painted finish.
AZ
Coverite Silkspun
I use silkspan (not Coverite Silkspun) with nitrate dope to cover balsa prior to painting, but it is not the same stuff as the Coverite iron-on silkspun, which is heavier and stronger.
Clair
Clair
