Bi-plane ID
TX
Bi-plane ID
Does anyone recognize this airplane?[sm=72_72.gif] I bought it for practically nothing. It appears to have been a kit vs. an ARF. The lower wing is not installed but laying under the plane. It appears to be large .40 size or possibly a small .60 size. Length is approximately 36" with wing span approximately 46" (top wing) and 42-43" (bottom wing). It uses 4 servos (1 aileron, 1 rudder, 1 elevator and one elevator. I would guess the flying weight to be about 7 pounds.[sm=tongue_smile.gif]
RE: Bi-plane ID
I don't know what it is, but it's good looking plane. 7 lbs though on a 46" span is quite heavy. I've got a SuperAeromaster bipe I built from a Great Planes kit and it weighs in at 9 lbs and it is 54" span. It called for a 91 or 1.20 four stroke in it. I couldn't figure a way to shoe horn in the 1.20, so I settled for a 91 magnum four stroke. I have yet to fly it though.
Check the engine mount if it is still in and make a guess on engine from it. I doubt that a 46" span would be happy with a .40. Maybe a 70 four stroke though. A good look at the interior construction will give you a clue. From the looks of the construction, the wire landing gear setup, I'm guessing this plane is probably 70's or 80's vintage. Just a guess though.
Don
Don
TX
RE: Bi-plane ID
Don,
Thanks for at least looking. Apparently the plane had a 2 stroke in it at one time. It has two holes in the bottom of the cowl which indicates a pitts style muffler and it has a round opening on the right side of the cowl (not seen in the pictures) that could have been for a .60 size engine. If the hole was just cut big I guess a .40 size could have been used too. Whoever built the plane (the person I got it from didn't know who built it) did a really great job. The monokote covering is almost perfect despite it's age (whatever that is). Hopefully someone will say "I had one of those once" and fill me in on the details.
Sonnytex
Sonnytex
BC, CANADA
RE: Bi-plane ID
That would be a Great Lakes from Modeltech. It was an almost ready to cover kit from about ten years ago. If you do a search on here, you'll find a bunch of threads about that plane. It is a 40-size.
TX
RE: Bi-plane ID
Thanks Deadeye,
I have read this thread, as directed by another member. If everything (and I mean everything) I have read is true it appears I may have an impossible flyer on my hands. But...... One must try regardless of the force not being in my favor.
Sonnytex
Sonnytex
BC, CANADA
RE: Bi-plane ID
I just finished one that people said didn't fly either. I had read comments like "I've never seen one make a second flight," but I gave it a shot anyways. I've probably got about 30 flights on it now. It's a handful, but far from unflyable. Give it a shot, and take it easy; it might not be so bad.
I know that one, because I was looking for one a while ago. I didn't find until I had given up and bought something else.
TX
RE: Bi-plane ID
Icegs,
Well, as you know, a real modeler does not give up on a plane just because someone else said it's no good. Kinda like having someone tell you a movie is bad or a certain restaurant has bad food - you don't know until you try it yourself. I will take some of the recommended mods if I think they will help. Thanks for the interest and opinion.
Sonnytex
Sonnytex
TX
RE: Bi-plane ID
Hey JimO,
Thanks for the offer - that would be great. Also, thanks for a rare up beat comment about the plane. Seems like 99 out of 100 didn't like it too well. I have already started some repairs on the plane. I will also incorporate a couple of the ideas by the others such as moving the servos farther forward. I also plan on installing an OS 61 4-stroke (1980's vintage) on it. That in it's self will put more weight to the nose. Again, thanks, the paperwork would really be appreciated.
Sonnytex
Sonnytex
My Feedback: (7)
RE: Bi-plane ID
Three things I remember, The CG is very critical, keep power up on landing and don't horse it off the ground. Power up and she will lift off on her own quickly. I had mine for two years till I lost her to a new member switching on for range check as I was landing.
