control horns for nitros ultimate 120-55"
MA
Due to the fact that the instruction manual is lousy , I dont know which control horns go where . The ARF kit has 5 large control horns and four smaller control horns . I was wondering if anyone knows which ones go on which control surface ?
My Feedback: (26)
RE: control horns for nitros ultimate 120-55
Smaller ones may be to connect the top and bottom ailerons. Some kits supply small horns with instructions to cut off the first three of the four holes in that application. An example is the Great Planes Super Skybolt. For that example, you could go to GP's website or Tower's and look at the instruction manual on line to see what I'm talking about.
The 4 small horns are for the ailerons rod, I will see if I still have my manual for my bipe, if I do I will pm you. they do NOT sit same distance in from top to bottom, they are different to allow for same throws, the angle of the tapers on your ailerons will throw different if set to the same.
MA
Hey guys , thanks for the info , looking at the skybolt manual I got what I need . Thanks for the replys .
