Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)
Reply
Old 02-21-2012, 04:52 PM
  #626
SunDevilPilot
SunDevilPilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)
I finished up the paint on the wings today. All went well.
I have quite a bit of painting supplies left so there should be no issue with getting the model completed. I think the only stuff left for paint is the windshield and the upper cabin.
I put some long bolts into the holes / blindnuts for the struts allowing me to set the wings down on the bolts and not the bottom of the wing.
SunDevilPilot
ID:	1730128   Click image for larger version
SunDevilPilot is offline
Old 02-21-2012, 05:09 PM
  #627
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good,
FYI you can also get the same ends in 2-56 (threaded and solder on). I use the same system for my 33% Waco and 33% J-3.
Later!!
Anthony
WacoNut is offline
Old 02-21-2012, 07:40 PM
  #628
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I really wanted to see what the brace wires looked like on the plane so I went ahead and installed them. I'm really happy with how the paint on them turned out. It was just split second decision to paint them.
SunDevilPilot
ID:	1730186   Click image for larger version
Old 02-21-2012, 09:39 PM
  #629
Flyitorcrashtrying
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
they look nice wth the ends unpainted too
Flyitorcrashtrying is offline
Old 02-22-2012, 03:08 AM
  #630
malitape
malitape's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anthony,
Do you have an item number for it?
pete
malitape is offline
Old 02-24-2012, 05:34 PM
  #631
FlyBy8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SDP, beautiful job on the build. I started reading from page 1 and couldn't stop.
I am currently building an old Dynaflite PA-18 kit and have really enjoyed your work.
Are those Dubro 6" balloon tire you are planning on using? Give is kinda a "Bush Plane" look. That is just exactly what I am after.
FlyBy8 is offline
Old 02-25-2012, 07:18 AM
  #632
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks FlyBy8!
The tires are the 6" Dubro inflatable tires.
I like the bush plane look too.
Here are a few pics I got at last years Copperstate Fly-in, a great time!
SunDevilPilot
ID:	1731622   Click image for larger version
Old 02-25-2012, 08:12 AM
  #633
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now that most of the painting is complete I am going to start the final assembly of the plane. I decided to start off with the wings. I just completed the final assembly of the servos / hatches. Next I will solder up some servo wire extensions then install the servos into the wings. After that I will glue in the aileron and flap hinges / surfaces. Then on go the struts.
SunDevilPilot
Old 02-25-2012, 10:56 AM
  #634
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just finished up the final installation of the Aileron and Flap Servos into each wing. I used a piece of string with a fishing sinker weight on one end to thread the wires through the wing. I just dropped it down the hole in each wing until it went from the aileron servo bay to the root. Then I taped the extensions to the string and pulled it through, easy.
All bolts got a little lock-tight.
After I mount the wings to the fuselage I'll cut each extension to the correct length and solder up the ends. I am using some DIY extensions from AirWild. I have used them before and they work great. A little time consuming but you do get a superior extension.
I crimp the extension pins onto a pre-tinned wire then heat up the pin melting the two together.
Each connection point is secured with some heat-shrink over the connectors.
SunDevilPilot
ID:	1731699   Click image for larger version
ID:	1731700   Click image for larger version
ID:	1731701   Click image for larger version
ID:	1731702   Click image for larger version
Old 02-25-2012, 01:32 PM
  #635
HoundDog
HoundDog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SunDevilPilot
SunDevilPilot
There's still time to put a "REAL" Gas Motor in it. "Lectric's for ladys" OH! am I in Trouble now.
HoundDog is offline
Old 02-25-2012, 01:52 PM
  #636
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You asked for it Mike!!!!!
A view of your future!
http://youtu.be/Nn__9hLJKAk
Phil
Old 02-25-2012, 01:59 PM
  #637
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Moving along..... I just finished installing the flaps. Hinges were installed with some 30 minute epoxy.
First I used a coat hangar to put some epoxy down the hinge hole. Then I put some epoxy on the barbed portion of the hinge, wiping it off until only the barbs were full (Prevents squeeze out as hinge is inserted). Then I put the flap on the wing. All went well.
I'm going to wait about an hour for the flap glue to setup then I will move onto the ailerons.
No need to protect the hinge knuckle as it is not in contact with the wing or the flap.
SunDevilPilot
ID:	1731796   Click image for larger version
ID:	1731797   Click image for larger version
  #638
TripleDeucer
TripleDeucer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good one, SDP
TripleDeucer is offline
Old 02-25-2012, 02:11 PM
  #639
knucklebutt
knucklebutt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your doing my favorite part.
Taking all those sub assemblies and puttin em together. woopie
Denis
knucklebutt is offline
Old 02-25-2012, 02:16 PM
  #640
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: knucklebutt
Denis
My favorite part too..... All that thought / work coming together for the first time. Good to see everthing turning into an airplane!
I can't wait to get to the struts... That is when I will put the wings onto the fusealge for the first time after paint.
Phil
Old 02-25-2012, 02:57 PM
  #641
HoundDog
HoundDog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Denis
Phil
Favo-Rights Part's is the Maidens Flights ther Young'en .. Got's a good Idea'er. Sees ya ben doen all them maidens fer Eddy and he's onleys done Wrecked one "CUB" ( Who Wrecks Cubs anyways) maybees O'l Eddy "Ricko-Backer" Sheep Herd, should be maiden her fer ya. LOL
Ifs ya works real diligents like, maybe's we sees her Monday .....
HoundDog is offline
Old 02-25-2012, 08:48 PM
  #642
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ailerons installed on both wings..... Process was the same as the flaps.
SunDevilPilot
Old 02-26-2012, 05:01 AM
  #643
AmishWarlord
AmishWarlord's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SDP, those wings look great!
You really hit it with that shade of red. Can't wait to see her completed and out in the daylight.
Those servo hatches came out awesome also. Love the colored horns and the high quality fasteners your using.
Those exposed hinges on your flaps look better than I thought they would. On my PA-18 convention I think I'm going with off set hinge plates on the flaps. I'll have to do some mock ups to see what the best way for me to make the plates with the hingpoints is.
I was shocked to see some Robart ¼ scale landing gear for the Balsa USA Cub's 7-¾" fuselage come up on ebay this week. I grabbed a pair since they seem to be always back ordered.
AmishWarlord is offline
Old 02-26-2012, 09:22 AM
  #644
malitape
malitape's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Phil
Quote:
AirWild
Great response. I like both
pete
malitape is offline
Old 02-26-2012, 09:24 AM
  #645
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More progress...
This morning I put the struts back together and bolted them up to the wings. In an effort to get the wings 100% done I will install them onto the fuselage, cut the servo wires to length, and put the connectors on the extensions. After that I can plug the servos in, adjust the centers, then make the pushrods. For the rods I am using some carbon fiber rod with titanium ends and 4-40 ball links. The pushrod set was ordered from Central Hobbies.
Lunch time but more to follow.....
SunDevilPilot
ID:	1732198   Click image for larger version
Old 02-26-2012, 12:41 PM
  #646
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I mounted up the wings and cut the servo extensions to length. I took the opportunity to take the plane out into the sun for a little photoshoot.
SunDevilPilot
ID:	1732318   Click image for larger version
ID:	1732319   Click image for larger version
ID:	1732320   Click image for larger version
ID:	1732321   Click image for larger version
Old 02-26-2012, 01:51 PM
  #647
G8er
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lookin good, at first I was Woa! thats a lot of flap deflection then I realized the servos are not installed/set up >.<
G8er is offline
Old 02-26-2012, 01:56 PM
  #648
TripleDeucer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice Phil. Too bad I'm not in AZ to see it fly.
Old 02-26-2012, 02:15 PM
  #649
knucklebutt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually Super Cubs have 40 deg of flap deflection, not too far off
if you can get about 20 mph wind down the runway and the 40 deg of flap plus a bit of throttle you can pretty much hover !!!!
Denis
Old 02-26-2012, 05:06 PM
  #650
SunDevilPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My goal was to get the wings 100% done today, I got to 99%. Servo extensions are complete and color coded.... I put a different color heatshrink on each wire before I put on the servo connector.
Then I made the pushrods for the ailerons and flaps but they are drying now. The only thing left is to install the rods.
First I centered up the servos (Flap servo was set full back which is 0 degrees flaps) then I measured the distance for the rods. The carbon tube was cut to length then cleaned in an alcohol bath. After everything dried I used a toothpick to work some JB Weld down into the tube. After I was sure the inner walls of the tube, in the area of the titanium ends, was covered I coated the titanium end with JB Weld. Then I worked each end into the tubes. The rods have to be clamped because of the air pressure in the tube. The JB Weld is thick enough it takes a little while for the air to escape. The pressure wants to push the ends back out of the tube.
Pictured are the rods for the right wing.
JB Weld, like epoxy, cleans up with some rubbing alcohol. I just make a mess and wipe it down once clamped. I have done several of these type rods before and they are rock solid.
SunDevilPilot
Reply
Display Modes
