If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 39 of 44 FirstFirst ... 293738394041 ... LastLast
Results 951 to 975 of 1095
  1. #951
    SunDevilPilot's Avatar
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)
    Bottom of the right wing is now covered.
    I have to say, every time I use SolarTex I am amazed at its ability to go around a wing tip. I just turn the temp up a bit with the iron, warm the covering in advance of the curve, and bend it into place. It really cant be easier!
    Taking a 15 minute break then onto the top side covering.
    SunDevilPilot
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1816300   Click image for larger version.
ID:	1816301   Click image for larger version.
    SunDevilPilot
    Cub Brotherhood # 47
  2. #952
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Right wing is now totally covered. I plan on going back over both wings with a little hotter iron to tighent things up right before painting and I still need to cut / melt the holes for all the hardpoints, servo hatches, and strut screws. I use a cheap solder iron for the screw holes and an xacto for the servo hatch holes.
    That's it for this weekend.
    SunDevilPilot
ID:	1816333   Click image for larger version.
    SunDevilPilot
  3. #953
    Join Date
    Jan 2006
    China, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    SDP I am building a 1/4 scale Jack Capen PA-18, those airportpictures you posted are a great in helping my build. Thank You
    Ken
    Wherever conversion engines are outlawed, only outlaws will have conversion engines.
    ULTA SPORT BROTHERHOOD #8
  4. #954
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: box car
    I've never heard of that one, so I looked it up. Found a few photos of one, looks good!
    I saw where you were researching the plans, you making a build thread?
    SunDevilPilot
    SunDevilPilot
  5. #955
    Join Date
    Jan 2006
    China, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have been making changes to the plans as far as the wood they used. This is the list of wood used in the plane, bass wood, plywood, maple, mahogany, spruce, luan, and 2 5x5 1/4balsa. Very heavy plane at 21#, used a 38 gas. I am going to try and get that down to about 16# and use a 30 gas. All the controls are pull-pull cable, all that will be gone, first time seeing cable flaps and ailerons in my 60 years of modeling. A build thread, I would be to slow for these guys.
    Ken
  6. #956
    Join Date
    Mar 2006
    Toronto, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: SunDevilPilot
    Right wing is now totally covered. *I plan on going back over both wings with a little hotter iron to tighent things up right before painting and I still need to cut / melt the holes for all the hardpoints, servo hatches, and strut screws. *I use a cheap solder iron for the screw holes and an xacto for the servo hatch holes.
    SunDevilPilot
    FWIW, fabric is the only way to cover a compound curve, such as your wing tips. It always works out perfectly. The weave of your fabric is what lets it conform to the complex shape.
    As for tightening, it's the same as the Koverall which I use. The dope is what really causes the shrink. You'll never get the heat shrink fabric as taught as it becomes once the dope shrinks it. And once it's all shrunk and painted, that adds to the integrity of the iwng. It strengthens things considerably. That's something a plastic iron on covering won't do.
    As an aside, Sig mentions that in the instructions for their 1/6 Cubs. They warn that the wing structure as designed is not suitable for the iron on films due to their lack of added strengt.
    In any case, it's nice to see that you have rebuilt your plane. Very nice. Wish you all the best with the "new" version.
  7. #957
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: do335a
    SunDevilPilot
    I can hardly believe that I finally read another fellow showing the advantages of fabric and aircraft dope.
    Another surprise is that do335a is nearly my next door neighbor. Wherever he is in Toronto I am a bit west of the Pearsen Airport..
    It would be nice to meet sometime. You could send me a PM and we could have lunch together.
    Zor
  8. #958
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This morning, as planned, I put the color onto the bottom side of each wing. Everything is coming along.
    I am off from work this coming week so maybe on Wednesday or Thrusday I will spray the top sides of each wing completing that part of the project.
    Hopefully this week I can cover up the fusealge, gear, and start painting on the fusealge parts + struts.
    There is a bunch to do but we're getting there.
    SunDevilPilot
    SunDevilPilot
  9. #959
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got done at work a little early today so I came home and jumped right into painting the top sides of the wings.
    At this point the wings are completely repaired.
    Next, I will trim and prime the cowl. When the cowl is ready for the final prime I will strip the landing gear and prime them along with the cowl. I will also prime the main struts. Once all that is done I will begin covering the fueselage.
    SunDevilPilot
    SunDevilPilot
  10. #960
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Too windy outside for the painting to continue... However, the primer was dry enough to allow the gear to get recovered. I drew a template onto my cutting surface then cut to shape four pieces (Two one direction and two the opposite).
    I covered the bottom side first to have the overlap from the top side appear on the bottom and out of view.
    The covering doesn't stick very well to the metal framework so you have to be really careful as you work the first piece on. Once the top side goes on, and sticks to the first, the covering becomes permanently attached.
    Pictures say a thousand words....
    SunDevilPilot
ID:	1818851   Click image for larger version.
ID:	1818852   Click image for larger version.
ID:	1818853   Click image for larger version.
    SunDevilPilot
  11. #961
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Weather turned a little cold a little fast around here but I managed to get the cowl and struts painted as planned. I think I was pushing the limits of the paint in terms of cold but everything went well.
    This Tuesday I will try and get the fuselage recovered and then next weekend I can paint the cream color onto the fuselage.
    SunDevilPilot
ID:	1819522   Click image for larger version.
    SunDevilPilot
  12. #962
    VincentJ's Avatar
    Join Date
    Mar 2011
    Peterborough, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks fantastic SDP, just curious, how cold does it get in your part of the world?
    VJ
    Ryan ST-A Brotherhood #2, Sig Brotherhood #143
  13. #963
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: VincentJ
    On a few occasions in winter it will get down to the 20s-30s. During the day it warms back up to the 50s. Not too cold.
    That being said, The Klass Kote data sheets recommend painting in weather warmer than 70. I bettery hurry or I'll miss my window until the end of winter!!
    SunDevilPilot
    SunDevilPilot
  14. #964
    Join Date
    Oct 2005
    Yellowknife, NT, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: VincentJ
    Looks fantastic SDP, just curious, how cold does it get in your part of the world?*
    Just curious, how cold does it get in YOUR part of the world?
    Cub Brother #10
    Waco Brother #221
  15. #965
    VincentJ's Avatar
    Join Date
    Mar 2011
    Peterborough, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here in Gods' country we'll see temps well below zero, as cold as -10. I'm sure that is warm in contrast to what you see up in Canada!
    VJ
  16. #966
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cub Brother #10
    Waco Brother #221
  17. #967
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Long building season
    Cub Brother #10
    Waco Brother #221
  18. #968
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Weather at our flying field is very localized, thanks to the adjancet mountains. Today flying was "blown out" so I am back home and will try and get my fusealge recovered a little ahead of schedule.
    SunDevilPilot
    SunDevilPilot
  19. #969
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bottom recovered... Lunch, then onto the sides.
    SunDevilPilot
    SunDevilPilot
  20. #970
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just finished up recovering the right side. Onto the left.
    SunDevilPilot
    SunDevilPilot
  21. #971
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm tired.. Started covering the remainder of the fuselage at around 800 AM. It is now 700 PM and I just finished putting on the cream color onto the fuselage. I'm trying to beat the cooler weather of winter. The cream was a little difficult to spray in the setting sun / cooler temp so I got a few runs on the gear parts. Fortunately the fuselage was perfect. I'll sand the flaws on the gear next weekend and touch up those parts.
    Now that the cream is on I should be able to tape and paint the red onto the fuselage completing the paintwork next weekend.
    SunDevilPilot
ID:	1820149   Click image for larger version.
ID:	1820150   Click image for larger version.
ID:	1820151   Click image for larger version.
ID:	1820152   Click image for larger version.
    SunDevilPilot
  22. #972
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You are doing lots of progress and very nice work as always.
    Thanks for the pictures.
    Zor
  23. #973
    VincentJ's Avatar
    Join Date
    Mar 2011
    Peterborough, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Resurrected from the bin ! Won't be long before she takes flight once again. Nice work, haven't seen you work this fast before...
    VJ
  24. #974
    Join Date
    May 2002
    Gilbert, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: VincentJ
    It was, and will be, my favorite plane. I was heartbroken when it crashed. I want it back!
    SunDevilPilot
    SunDevilPilot
  25. #975
    WacoNut's Avatar
    Join Date
    Jan 2005
    Blanchester, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glad to se you didn't scrap it out. Mine was damaged way beyond what your was and I almost rebuilt it but I had a 1/3 kit on the way so I just gave it to a friend and built the 1/3 for myself.
    Later!!
    Anthony
    WACO Brother #30 Cub Brother #17
    It's not the hours you put in It's what you put into the hours.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
