Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)
#178
RE: Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)
I received all the wood I needed and have started building the left wing. No need for photos at this point as it looks just like the right wing.
The spruce spars from Aircraft Spruce are really nice quality, I will order from them again. The balsa from sig was a little less than perfect but decent enough.
So far I have the bottom sheeting, bottom spars, and the wing ribs assembled. After the lower assembly glue dries I will continue. For now it is weighted down.
SunDevilPilot
SunDevilPilot
#179
NC
Sundevil,
I've built a lot of cubs over the years and can tell you that you will be very pleased with the sig 1/4 scale, best one around.
You & Waco Nut do top notch work
#180
I am really looking forward to seeing this build head toward compleation and flight! I know where to lay my hands on either the Sig or Balsa USA 1/4 Cub kits, and would love to do a PA-18 conversion. What do you guy's think would be the better choice for this build? Right know I'm leaning toward the Sig.
#181
I have been really happy with the Sig kit but I have been wanting to build something from Balsa USA, possible a WWI bi-plane. I have ordered wood from them before and it was really nice stuff.
I picked the Sig based on my past experience with their stuff and because i had seen many of their 1/4 Cubs over the years. In my little circle the Sig is the benchmark for a 1/4 Cub.
I don't think you can go wrong with either.
Below is a photo of the wing in its current state. I need to cut the sheer webs, which can be done easily and perfectly on the table saw.... However, there is a monsoon storm outside so cutting them will have to wait until tomorrow afternoon. Monday morning is for going flying!
(Some may see the mess, which is rare around my castle!)
SunDevilPilot
SunDevilPilot
#182
My Feedback: (129)
I'm presently working on a 1/3 BUSA Super Cub. It's a great kit and is going together good as I have time. No real deadline to meet. I do prefer the way Sig marks the pieces of wood, whereas BUSA does not and you have to study the plans and book more to understand what goes where. Both enjoyable kits.
#183
Oh,oH I think I might have to drive up to LHS at lunch and pick up the Sig, they had a 4*120 TOO! ....... Great Build SD Pilot.
#186
AZ
Phil,the BUSA Fokker D-7 gets great reviews, comes in 1/4 and 1/3 scale. Its a heavy sucker though. Or you could build a DR1 and join the Jasta. The new DR1 is comming along.
#187
I now have two wings that are free from the building board. Both came out nice and straight. Next step is to install the hard points for the struts then add the wingtips. Once that is done the control surfaces (Ailerons and flaps) will be removed, completed, and hinged. At that point most of the construction of the components will be complete. It will be a matter of putting the tail surfaces on and then onto servo installation. Getting closer!
SunDevilPilot
SunDevilPilot
#188
NC
Not as many sticks in that box as there once was hey sundevil.
Man I don't care what nobody says that is a lot of building.
The finished product will be well worth it.
#189
I am glad to see the big box of sticks finally starting to thin out. I am also glad to see the wings mount up as planned despite all the modifications I made to the fuselage. Everything is coming together!
SunDevilPilot
SunDevilPilot
#190
I really didn't want to install the jury strut mounts, I was afraid to cut into my nicely sheeted wing to inlay the mounts, but I forged ahead. You have to notch the sheeting at the spar. The process was not that bad once I got started. I clamped the mount to the wing, went around a few times with a sharp xacto knife, then cleaned out the balsa using my dremel with a router base attached. The dremel router make it easy to clean off the spar of the balsa sheeting and associated glue.
I did modify the jury strut mounts in that I added a 1/4" spacer and an additional piece of ply to "Capture" the spars within the mount. The plans call for a single piece of ply to be glued to the spars and that's it. Sure, it is just the jury strut mount but I don't want to risk a failure given the fact the struts are functional (AKA Required) to keep the wings from folding. The mounts use 4-40 bolts and blind nuts epoxied to the rear. The bolts will also hold the mounts together and keep the spar captured.
The mount for the actual struts are next and are built just like the jury strut mounts.
The mounts have yet to be sanded so there is a little excess glue, which is perfect.
SunDevilPilot
SunDevilPilot
#191
When I did mine, on the clipped wing version, I cut the holes in the sheeting before I glued it to the wing frame. It seemed a bit odd to me to do it in the suggested sequence.
As for their functionality, they never let go and neither did the mounts, no matter how many Gs I pulled with that plane. I did ultimately experience the same condition which others found. The brass tubes cracked at the bends where they are flattened.
#192
ORIGINAL: do335a
While not quite scale I plan on changing the jury struts to some airfoiled aluminum, like shown below on my 1/5th scale cub. Hopefully that will last longer than the bent brass of the stock kit. I have a couple years of flights on the 1/5th scale and there is no sign of any issue. Like the 1/5th cub, this one will be electric so there will not be the damaging effects of engine vibration.
SunDevilPilot
#193
All the mounts for the Struts / Jury Struts are complete. All mounts were built in a similar manner, ply plates overlapping the spars on both sides with a ply core in the middle. Each has a 4-40 blind nut epoxied into the back side. Should hold up well.
It is really starting to look like a Cub now!
Next up is the curved wingtips.
SunDevilPilot
SunDevilPilot
#194
My Feedback: (16)
AL
Im building the clipped wing version and I have been following this tread, Its been a while since i did the wing/strut mount on mine but i remember it being odd in sequence following the manual. I have not flown mine yet but i have seen alot of the 1/4 scale cubs get tossed around without any problems with the stock setup sig recomends.
#195
NC
Hey SDP, if your willing to give up a lot of efficiency, Hobby King has some very nice looking cherry laminated props with old style rounded tips. Shipping will cost more than the prop but it's still a good price. You just have to wait for them to get your size in stock before you order one.
http://www.hobbyking.com/hobbyking/s...idProduct=5765
#196
AB, CANADA
Nicely done, SDPilot. Glad to see you back at this one. My BUSA 1/3 Supercub is coming along (I have a thread on RCScalebuilder) and I'm toying with the idea of doing a 1/4 scale when I'm done so as to have an easier to transport PA18. I like your adaptation. Might have to steal some of your ideas...
Tom
Tom
#197
ORIGINAL: AmishWarlord
SunDevilPilot
#198
Today I was able to get a good start on the wing tips. They went on without any major issues. I still need to laminate some balsa around the curve, add the leading edge stock, finish the wing tip sheeting, and carve it all to shape but I can almost see the end of the tunnel in terms of the major woodworking.
Is somewhat refreshing to just take the parts out of the box and put them on. It seems I have modified so much of this kit I plan each step spending about ten times as long as it should.
So far I'm really proud of my work.
SunDevilPilot
SunDevilPilot
#199
NC
Man you ought to be.
You would be surprised of the guy's who would not even attempt to build this kit.
I always said that a sig 1/4 scale cub separates the men from the boys.
#200
NC
That's some really nice wood those ribs are made of. Sig did a good job in balsa selection there. Was this a older kit or is this a new production one?
