Building the House of Balsa A7 Corsair Propjet
Reply
Old 07-01-2009, 11:26 AM
McLeodAviation
McLeodAviation's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Building the House of Balsa A7 Corsair Propjet
[/quote]
I will paint it in the grey and green scheme. I have always liked that scheme.
[/quote]
I like it too. Here's a picture I found on the Internet.
McLeodAviation is offline
Old 07-01-2009, 12:24 PM
CastorTroy2150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any idea on covering you will use as you will be painting? I am curious because I am interested in painting my builds but havent done the research to know what covering is best to use.... Any idea on weight so far and what the factory estimated weight to be on the finished project? Once you finish this one, you will have to get the plans blown up into 2x that size and build on with retracts
CastorTroy2150 is offline
Old 07-01-2009, 05:45 PM
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: CastorTroy2150
I always use Ultracote. It is pretty hard to mess up with that stuff. Thats my experience anyway. That stuff will shrink like nobody's business. When I paint it, I just sand a very light bit all over it and spray it. When finished, I spray dullcote or clearcote over the paint and decals for fuel proofing. All the paint is from wal-mart. The wing loading is supposed to be 23oz. sq.ft., the manual does not give a finished weight. It is actually a pretty good size airplane for a House of Balsa kit. I think most folks see that it is a H.O.B. kit and just assume that it is small. The wingspan is 40" and the length is 37". Tonite, I will tackle the fuselage. I have read over the fuselage build several times b/c it builds very different from the conventional box type fuses. We will see how it turns out. Thanks for all the notes and helpful info from everyone......
lear31A is offline
Old 07-01-2009, 10:42 PM
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okie Dokie, I started on the fuselage. Got a late start this evening (took the wife and kids out for sushi for wifes B'day). Amazing how I was looking at those chopsticks thinking that they would be great for wing spars! This hobby is a sickness!
Believe it or not, this is 10 pieces of gluing. It took a while for the glue to set since it is gluing plywood to balsa. Tomrow nite I should be able to knock a huge dent in the fuselage......
lear31A is offline
Old 07-01-2009, 11:00 PM
CastorTroy2150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I believe "Sickness" is quite an understatement...., The fuse on the FW-190 I built was quite different as well... but build strong. May want to consider drilling some holes where you can to keep weight down..I think I saved several ozs by swisschessing it... Cant wait!
Old 07-02-2009, 12:53 AM
  #31
multicasting
multicasting's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
McCleod, that's a common picture. I love that one. I used to have it hanging on the wall as a kid. It was one of LTV's small PR posters on 9x11 paper. Think of it like an oversized trading card. On the back were the specs. My Pop worked at LTV from 1963 to 1999. I was raised on the A-7. It wasn't sexy, but I always thought it was a beauty. I guess I was biased.
Bob
multicasting is offline
Old 07-02-2009, 11:58 AM
  #32
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still trucking along. Drilling holes and installing blind nuts,etc. Got help from my youngest little girl!
ID:	1228620   Click image for larger version
ID:	1228621   Click image for larger version
ID:	1228622   Click image for larger version
ID:	1228623   Click image for larger version
lear31A is offline
Old 07-02-2009, 11:23 PM
  #33
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Knocked a small dent in the fuselage tonight. It should start moving more quickly from here. keeping everything perfectly square while the glue dries is time consuming.......I am just loving this build. Straight forward as it gets, building it step by step with no modifications so far.
lear31A is offline
Old 07-03-2009, 11:37 PM
  #34
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some more progress. Man, this thing is getting heavy! Everything just fits like a glove. Cant wait to fly this thing!
ID:	1229509   Click image for larger version
lear31A is offline
Old 07-04-2009, 12:00 AM
  #35
multicasting
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am so freakin' jealous. I have got to find me an A-7 HOB kit.
Bob
Old 07-06-2009, 08:19 PM
  #36
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I mentioned earlier that the fuselage builds differently. Well, the tail section took a bit of "noggin scratching" to get straight and stable. I also will cover as much as possible before permanantly installing. So, with making the hatches on the bottom and all the sanding, it has been a little more time consuming that I thought. The fuselage weighs as much as a bag of bricks (the red ones)! So, I am definately using the 46FX. It will just have to land at Mach3! Should get alot more done tonight.........
ID:	1231001   Click image for larger version
ID:	1231002   Click image for larger version
ID:	1231003   Click image for larger version
ID:	1231004   Click image for larger version
lear31A is offline
Old 07-07-2009, 01:11 AM
  #37
McLeodAviation
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: lear31A
Awesome! Now we're talking jet like performance!
Why is she so heavy? Just heavy balsa? It is amazing how much the weight of balsa can vary. The contest grade is super light.
Was that your idea to put the servos by the tail or is that shown on the plans? That will definitely help offset a big motor.
Old 07-07-2009, 10:46 AM
  #38
Gray Beard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You were thinking about chop sticks, guess what I was thinking about when I was out chain sawing wood and brush cutting!!
This is parhaps the stoutest HOB plane I have ever seen, they really made this one to last. The P-51s are pretty good too but this one really has some meat to it.
Gray Beard is online now
Old 07-07-2009, 11:02 AM
  #39
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Gray Beard
You are right, it is stout as a dinosaur turd! I waited until I completed the fuselage to see where I could cut some lightening holes, but I really dont see anywhere b/c the way it is made. One of the hatches on the bottom is plywood, I can make another one out of balsa and that will help a little.
I built the cockpit, I cant have an airplane with no cockpit! I know it is just a propjet, but it is really neat and will look different when complete. I also made some missle rails to attach to the bottom of the wing. I am going to the LHS to buy some stronger gear wire today and also make a longer nose wire for a bigger prop.
ID:	1231388   Click image for larger version
ID:	1231389   Click image for larger version
lear31A is offline
Old 07-07-2009, 12:29 PM
  #40
Shouter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had one of these for awhile, It has sat unfinished in my garage the whole time. This thread is making me want to get it finished!
ID:	1231405   Click image for larger version
ID:	1231406   Click image for larger version
Shouter is offline
Old 07-07-2009, 01:13 PM
  #41
airbusdrvr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was looking through some threads and saw your A-7 build. Just thought I'd let you know that I have flown the very plane shown in the picture. The MB(Myrtle Beach AFB, SC) number 354. I was asssigned to the 354th Wing back in 1972-1975. That's been a long time and I'm not sure, but that plane may have even been deployed with us to Korat Royal Thai AB, Oct 1972 to Oct 1973. Don't have a clue where all my old pics are, but found these two in my desk.
learjet, your post I was responding to was the last one on page one. I didn't notice page two until after I posted a response, but I am referring to your post #25 pictures.
airbusdrvr is offline
Old 07-07-2009, 02:16 PM
  #42
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: airbusdrvr
learjet, your post I was responding to was the last one on page one. I didn't notice page two until after I posted a response, but I am referring to you post #25 pictures.
Wow, that is really neat. I have always loved these airplanes. I couldnt resist when I saw it.
Shouter: Thanks for the pics! Thats why I am documenting this little build, hopefully some of these older cool kits will come out of the hanger
I started beefing up the gear at the recomendation of another fellow. I figured I might as well make them look a little better. Better than just wire hanging down anyway. I used brass tubing of a couple different sizes and soldered them onto the gear before bending them (i bent whole nes gear). I will paint them white later and hopefully they will resemble some sort of struts.............
ID:	1231447   Click image for larger version
ID:	1231448   Click image for larger version
lear31A is offline
Old 07-07-2009, 08:03 PM
  #43
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished gear. Soldered and painted white. They are really stout now.
ID:	1231665   Click image for larger version
lear31A is offline
Old 07-08-2009, 07:12 PM
  #44
McLeodAviation
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking really good. Nice job on the simulated landing gear struts.
I figured out why the fuselage is so heavy. It's half plywood!
I see the A7 "Shouter" built also has the servos by the tail. Cool set up which helps balance the model.
Old 07-10-2009, 07:27 PM
  #45
Quikturn
Quikturn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You guys won't beleive this but I was just looking at one of these kits today at my LHS. Does anyone know how well these fly? I'm thinking about buying the kit after reading this thread.
Quikturn is offline
Old 07-10-2009, 08:20 PM
  #46
McLeodAviation
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Better snag it!
Old 07-10-2009, 08:34 PM
  #47
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Quikturn
Get it! Get it quick! They fly good, just land hot from what I have read............
lear31A is offline
Old 07-12-2009, 05:44 PM
  #48
Quikturn
Quikturn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
He shoots, he scores!
I went out and bought the A-7 kit but I may not get to it until next year. Too many other irons in the fire. I'm in the process of refurbishing a Super Hots 60 then I have a Phoenix Models F20 to put together before fall.
I am very interested in following this post so keep up the good work Lear31A! Umm, or should I say G150 (lol), kidding. Anyways, excellent work. I look forward to the next post.
FYI, I think this may be the kit version of Rich Uravitch's design.
ID:	1234795   Click image for larger version
Quikturn is offline
Old 07-12-2009, 06:30 PM
  #49
McLeodAviation
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice score Quikturn!
Old 07-12-2009, 06:37 PM
  #50
lear31A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Quikturn
Good job scoring the goods! I just finished the cowling (which was the most noggin scratchin involved so far). Will mount the wing tonight and get back to it.
G150....out, hehe
lear31A is offline
Reply
Display Modes
