Magic Box source
MI
Magic Box source
I am trying to locate a source that makes a device we used to call a "magic box." It was used to drive two accessory pushrods off main pushrod. This was often used to drive flaps with hinge lines swept at an angle to each other. Most involved an aluminum block which the pushrod wires ran thru and had machine screws used to lock the pushrods in place. The flaps usually had a strip type control horn. I saw them somewhere online in the lasts year or two but did not bookmark it (dummy!). Any help anyone can offer would be appreciated.
thanks,
bob
thanks,
bob
RE: Magic Box source
I have seen a similar system. In fact within the last couple of weeks I was looking at a kit that used that system and Tower Hobbies even had one for sale. I just did a search at Tower and had no luck. But I'm not sure exactly what the search term should be to find it. I recall some used that system in the World Models Intruder 90. And many other use the system. Someone will come up with a similar item/link shortly.
