UltraStick 60
UltraStick 60
I am having trouble installing a Saito(4C) on my ultra stick 60. I can't get the throttle linkage to line up right. The gas tank is in the way. no problem with a 2 cycle engine. I am using a saito(100). Any suggestions would be appreciated.
hi
I installed this exact setup for my little brother.
First toss that little brass link thing with the set screw, I had to make a Z bend to get it to work.
I also had to modify the suggested pushrod exit location, you may or may not ahave to drill a hole in the first bulkhead, I didn't but it would line up a little better that way.
If you'd like I'm sure my little bro would take some snap shots to show you.
Hope this helps
Hope this helps
