Aerotech JU87B kit build help
Hi All,
Fuond what I would I to build for my winter build. found it at my LHS comming in from out of town working. He was selling it for some body he knowed. The kit is from 1998 it hade the recpt in the box I paid the same price for the kit. The kit is made by Areotech International, The plane is a JU87B Stuka 60. It is a Balsa/Foam kit. This will be a first time build of this type of plane. Looking for a photo build to look at plus a lot of support.
What type of glues how to start build ect...
My Feedback: (-1)
RE: Aerotech JU87B kit build help
Step one, read the instruction book on the right at least three times before you ever think of touching the plane with any glue. As many years as I have been building I still do that. Sometimes a lot more then just three times. Most of the glues you will use with foam core are the water based wood glues like tite bond and epoxy. It's a good idea to test glues on a shuck if you aren't sure to see if it reacts to the foam. There is foam safe CA glues but I tend to even stay away from them when I'm building foam cores
Ju88b 60" Aerotech Kit
Hi all...received this kit a gift...Full kit minus plans. Can anybody supply an image of this plan to give a start. Most seems relatively obvious but the placing of fuselage parts/formers difficult without extensive trial and error. Would be most grateful.
Kindest regards
Tommac
Kindest regards
Tommac
