Astro-Hog Build
NJ
Astro-Hog Build
This will be my second attempt at building the "Astro-Hog". My first "Hog", while a fine looking airplane, was a handful to fly. As a matter of fact, I am still trying to figure out what went wrong. Having said that, I have been kit building and flying RC planes for more than 20 years and my first "Hog" was the first plane I build that had a problem.
This time, I will record each step along the way and I encourage any comments and especially those that point out any errors I may make.
I will be building the "Hog" as described in the plans as a tail dragger, except the landing gear will be 3/16" as opposed to the 5/32" as called for in the plan.
Following the instruction book (for the most part), here we go!
Pic 1 illustrates the top and bottom wing spars with the doublers and the larger landing gear blocks required to accomodate the 3/16" music wire. I ordered larger blocks from SIG when I ordered the "Hog". The larger blocks are 1"x6"x1/2" compared to the supplied L.G. blocks measuring 3/4"x6-1/4"x3/8". O.K., so I glued a 1"x1/4" piece of hardwood on the ends of the new blocks the achieve the same length. This will allow installing the new, larger L.G. blocks without moving the ribs.
Pic 2 illustrates the enlargement of the ply doublers to accomodate the larger L.G. blocks.
O.K., that's enough for tonight.
DaveB
DaveB
FL
RE: Astro-Hog Build
Hey Dave,
I built mine with the stock gear blocks in the wing
as a back up. I used a Dubro gear for my tail dragger.
Take your time, it's worth it.
Bob
NJ
RE: Astro-Hog Build
A little more work today on the "Hog". Started building the left wing. Finished the doublers and glued same to the W2 ribs. Also doublers on W5 ribs. Glued ribs W1 through W5 to the top and bottom spars. There was a little play in all the notches where they were attached to the spars. I don't know whether the spars are a little small or the notches were a little large. I would have been happier with a snug fit. After glueing, all ribs seemed securely fastened.
As far as glue goes, I will be using "Tite-Bond" or similar for most applications. Epoxy where appropriate, but I will try to avoid CA glue as it gives me respiratory problems when I use it for more than just a drop or two.
Also, I will be using a single servo in the center of wing as designed and also will build the 12 degree dihedral as called for in the plan. I still haven't decided the power, although I am leaning to installing the FS-70 4 stroke that was in (and still is) my first "Hog".
Company coming tomorrow, so no building until later in the week.
DaveB
DaveB
RE: Astro-Hog Build
Hello DaveB
I´ve built an Astro, and is a pleasure to fly, I bought another one for the future!
I installed the stock landing gear as taildragger, and works perfect.
With the the OS70 will be perfect, I fly with a YS63 and 13/6 and has more the enought power.
Respect to dihedral, I reduced it to 6º and has no problem in slow landings, and she can roll almost in the axis.
Take care in glueying the wings with the same incidence, and follow the incidences of plans, Engine, stabilicer, and wing. You should have no problem in your flights.
Also I installed 2 servos for ailerons in the same place of single servo, do the box a bit bigger and its done.
Ask you whatever you want!
Good luck in your building!
Carlos
Carlos
RE: Astro-Hog Build
DaveB, it's good to see that you are building a new Astrohog. I'm sure that many will be watching and wishing you good luck, especially after the problem you had with the last one.
All the best.....Chris, UK.
RE: Astro-Hog Build
The Hog is about as straight forward a build as you can get. I LOVED mine!! (see my screen-name!) The only mod I did was to take the dihedral out, and I think this is a very worthy mod. This plane was designed in the late '50's or early '60's when all the other gear (radios, servos, engines, etc.) were not up to par with what we have today. You will NOT be disappointed with less dihedral, mine was still about as forgiving as a trainer, yet would roll very axial!
Enjoy your build!
Regards,
Astrohog
Enjoy your build!
Regards,
Astrohog
TX
RE: Astro-Hog Build
ORIGINAL: spanishflyer
Hello DaveB
Hello DaveB
KY
RE: Astro-Hog Build
ORIGINAL: GhostRider32
What is the dihedral supposed to be according to the book?
Hello DaveB
Hello DaveB
NJ
RE: Astro-Hog Build
Dave sorry my first reply was short. At work. Anyways, I built exactly as per the plan including the dihedral at 12 degrees if I remember correctly. I have a Saito 82 on it and flys pretty well. It is a slow flier and the rolls are huge. Maybe you did not use the correct CG on it? It may have been heavier than intended? just some toughts.
NJ
RE: Astro-Hog Build
A little more progress on the "Hog.
Worth mentioning, if using "Titebond" glue or similar, when glueing the laminated wingtip bow, make sure the laminates are clamped or weighted down in such a way the laminate is secure. I have found that when using "Titebond" the laminates will tend to warp a little and separate while the glue is curing. Good clamping or weighting will prevent this from happening.
Another thing I did was to double the T.E. by glueing 1/4" x 3/8" x 2" pieces of balsa to the front of the trailing edge piece. This will provide a little more glueing surfaces for the aileron hinges. I thought the 1/4" trailing edge needed a little more "meat" to accomodate the hinges.
If you are building the "Hog" as a tail dragger and plan to install the gear in the wing, you may want to skip ahead in the instructions and install the landing gear blocks before glueing the bottom edge sheeting. It's easier to cut the slot for the landing gear block before glueing the sheeting to the ribs and spars. Also, because I installed larger landing gear blocks to accomodate 3/16" music wire, I had to enlarge the notches on the ribs supporting the l.g. blocks and for good measure I added a piece of tri stock for a little extra strength.
Leaving town tomorrow, so the "Hog" will have to wait a few days before I can get back to business.
DaveB
DaveB
KY
RE: Astro-Hog Build
NEED A LITTLE HELP, i'M BUILDING A HOG AT PRESENT . I'm getting ready to sheet the bottom and to top of the fuse. I came across sheets 7-8 3/32 balsa and cut on a wedge,one says fuse leftside,the other the right side.
No place in the manuel does it say anything about sheet 7,8 so do the go on top behind the cockpit of on the front at the firewall.
wattmeter[]
wattmeter[]
NJ
RE: Astro-Hog Build
Wattmeter,
Sheets 7 & 8 are the right and left fuselage sides respectively. They are to be cut out and then 1/4" sq. balsa stringer are glued to them. Check the instruction book, page 12, Step 4.
DaveB
DaveB
KY
RE: Astro-Hog Build
ORIGINAL: DaveB
Wattmeter,
Sheets 7 & 8 are the right and left fuselage sides respectively. They are to be cut out and then 1/4'' sq. balsa stringer are glued to them. Check the instruction book, page 12, Step 4.
DaveB
Wattmeter,
DaveB
Thanks for the wake -up
wattmeter[X(]
