what is wash-out?
WA
what is wash-out?
i posted this in the aerodynamics forum also, but it always seems pretty dead over there, so i'm going to post it here as well, and see who responds to it. what is wash-in and wash-out and what does it do and how do i build it in? i just got a set of plans to scratch build an extra 3.25 from rich urivitchand was curious about this. the plane builds pretty light anyway, wing span 47", right around2.75-3.5 lbs, wing loading 19-23 oz./sqft, 340 sq. in., powered by my trusty .32 from o.s.,so i'm curious if tip stalling is going to be a big deal with it.don't be afraid to throw it all at me.just never really thought about wash-out before. the only thing i know about it, is it has to do with the root of the wing stalling vs. the tip, or before at least, keeping the ailerons active. any other assistance would be great with figuring out this "mystery".
My Feedback: (162)
RE: what is wash-out?
As I recall, washout is where, at the wing tips, the trailing edge is reflexed up, slightly higher than the leading edge. better flying and stability habits. Helps with Wing Tip Stalling.
Vince
Vince
WA
how much should be adjusted into it and would you do this by intentionally building in a twist, per se, in each wing? maybe a couple degrees, or a 1/4 inch up on the trailing edge of the tip?
2 to 3 degrees.
I would believe the plane you're building does not need any wash out. Normally highly loaded scale planes do. Just built it straight. As stated the purpose of wash out is to force the wing to stall near the fuselage before the tip, this prevents auto rotation. As the wing stalls, speed increases moving away from stalled condition. Hope this makes sense?
WA
makes perfect sense. thanks. i was curious if it should be something to think about while building the plane, as to do it in the process.
SC
Based on the name of the model, it is a 3D type machine. With this in mind, the wing should be as straight as you can get it because the wash-out will become wash-in when you are inverted. I would think that inverted tip stalls would be un-good.
Cheers
Gordon
K4SD
Cheers
Gordon
K4SD
My Feedback: (-1)
Rich never mentioned 3-D in the MAN article when he designed the plane, it's just a small fun scale Extra. When these planes are designed the designer builds test planes and puts them through there paces, makes any mods or changes needed then sells the plans. The Extras aren't a design that tip stalls anyway but if Rich discovered this plane needed any wash he would have put it in the plans. I have built a few of his designs over the years, one thing I have noticed is he tends to build them a bit on the heavy side but I have never had one of his planes fall apart on a rough landing. The wings even stayed on with the bipes he designed, when I built them my landings really needed some help!!
Wash-out is an intentional decrease in angle of incidence across a wing span from root to tip. This is intended to decrease the tip angle of attack (AoA), which will cause a stall to develop first at the wing root and later at the wing tip. Because the lift developed by a wing *decreases* with increased AoA after the point of stall, an asymmetric stall at one wing root cause less of a rolling force than a stall at the tip. And a straight ahead stall will be less likely to develop into a spin than a stall compounded by an unwanted rolling tendency.
One might wonder how a wing can stall on one half asymmetrically and not on both wing halves at the same time (don't both wings have the same incidence, and therefore AoA?). The answer is relative airflow. If one wing is dropping relative to the airflow, that wing will will experience a higher AoA. So for example if the airplans is rolling left on base-to-final, and close to the critical angle of attack, that left wing panel has a higher AoA and will stall sooner than the right side. If that wing has washout, the stall will happen inboard rather than outboard, and will contribute less to an uncontrolled roll into a spin.
TX
Crash,
As mentioned above, do not build wash out if you plan to fly inverted. I've got a 1/4 scale GeeBee with 3 degrees of wash out at the tips. Although it will not tip stall, it also simply will not fly inverted. Full down elevator inverted will not stop it from sinking. Tip wash out is not used for aerobatic aircraft, either full scale or models.
WA
then it's settled. no wash-out. i'm glad, cuz i don't really want to try building it in. sounds like a pain in the butt. i was just curious if it was necessary and more curious of what the actual effects from it were. or how it worked, i guess.
My Feedback: (-1)
Usually if it's needed the designer will draw tabs on the bottom of the wing ribs so it is built in when you build the wing flat on your building board then you just remove the tabs when complete. You will see this on a number of kits when wash is required. True scratch builders have to do the math, those of us that build kits and from plans don't need to think about it.
WA
sweeeeeeet... andi thought the tabs on the bottom were just to keep the wing aligned properly to avoid twists or a warp. like on the topflight warbird kits. i didn't know it was intentional for inducingtwist for the washout. that's cool. you learn something new everyday. do you happen to remember the issue that he wrote the article in for the extra 3.25? i would like to read a little more about it if i could get ahold of it.
TX
ORIGINAL: crash bandicoute
sweeeeeeet... and i thought the tabs on the bottom were just to keep the wing aligned properly to avoid twists or a warp. like on the topflight warbird kits. i didn't know it was intentional for inducing twist for the washout. that's cool. you learn something new everyday. do you happen to remember the issue that he wrote the article in for the extra 3.25? i would like to read a little more about it if i could get ahold of it.
My Feedback: (-1)
WA
yeah, i'm deffinitely going to buy them from him. the bunch of it comes with the ABScowl (not impressed with that), the canopy and ABS wheel pants. not impressed with them either, but the whole set up is 20 USD. not bad at all. plus i've been experimenting with fiberglass, so i could probably reproduce a glass cowl. i checked at fiberglass specialties, and they don't have a cowl for the plane, but the wheel pants, if i decide to get some, are fairly descent priced. or i could balsa the pants. none of it too difficult. i'd probably pay 20 bucks for the canopy alone. i would greatly appreciate the article if you happen to find it. i enjoy reading about all of them, often wanting to try one. but lately, i've been hung up on the extra. i think i saw the plane a couple years ago in a plans listing.
My Feedback: (-1)
yeah, i'm deffinitely going to buy them from him. the bunch of it comes with the ABS cowl (not impressed with that), the canopy and ABS wheel pants. not impressed with them either, but the whole set up is 20 USD. not bad at all. plus i've been experimenting with fiberglass, so i could probably reproduce a glass cowl. i checked at fiberglass specialties, and they don't have a cowl for the plane, but the wheel pants, if i decide to get some, are fairly descent priced. or i could balsa the pants. none of it too difficult. i'd probably pay 20 bucks for the canopy alone. i would greatly appreciate the article if you happen to find it. i enjoy reading about all of them, often wanting to try one. but lately, i've been hung up on the extra. i think i saw the plane a couple years ago in a plans listing. [img][/img]
Hit me with a PM and I will send you the files when I get your address.
My Feedback: (-1)
I just read the building instructions and Mr. U does have wash out in the wing plus he has a partial flat bottom airfoil section to keep this little plane from being a complete hand full in the air. He covers how the wash is automatically built in on step #11, very easy.
