4*40 came in today
#77
TX
RE: 4*40 came in today
She covered the solid blue on the ailerons and the tri stock on the vertical stab, I did everything else. I'll let her know..... You get your engine in yet?
#78
Motor is here, looks fine. Funny thing, I ordered 4 new servos (all the same), 2 came with mounting screws, 2 didn't. [] It's been so long since I built a plane, that I've got to go dig around to find more hardware.
Enough about me, this is your build thread. So, how did it fly?
#79
TX
ORIGINAL: Zapped
The 4* didn't fly worth a crap. Actually it didn't fly at all.
While I was breaking in the engine, servo movement became very erratic. It ended up being that the switch quit working. Better to quit on the ground than in the air. It became intermittant, worked a little while and then wouldn't work for a little bit....... Red light on the receiver for a little bit then no red light for a little bit.......... I'm changing the switch now with a new one and plan on flying it tomorrow. Still trying to make the first flight on the plane and Aurora......
The Magnum .46 broke in well and showed good numbers for a new engine.Fai fuel with 80% methanol/20% oil tached at 11,800 on an 11x6 APC prop with 2.5 tanks of run time.
#80
How can HobbyPeople help when I ordered it from Tower Hobbies? They also forgot to include the RDS in my order, but I got that straightened out.
Well, the good news about the 4* is that you went thorugh the proper pre-flight measures to keep from losing the plane.
#81
TX
ORIGINAL: Zapped
Yeah, I would have hated to crash because of a bad switch...... It resembled a "radio lockout" where I could control it for a few seconds and then nothing for a few seconds. Just long enough to crash and blame it on the radio....... All during radio installation of the plane, never a single power issue then bam, on the first engine run, it got erratic. It was most likely caused by vibration but I threw the switch away so I'll never mistakenly use it again and find out. Funny thing is that it would work perfectly when it would come back and then drop out again without warning.
I'm to the point that since switches are so cheap, I'm considering putting 2 in parallel for every plane I have and just changing them both every year. Really, whats a few dollars a year for switches compared to a plane...... On this particular plane, I ended up changing the battery too because I just wasn't 100% sure it was the switch alone so why chance it?
#82
TX
Flight report..........
Flew the 4*40 about 7-8 times today and it flies well. Had a couple of deadsticks but not too big of an issue. The plane is surprisingly fast with the 2 wing bays gone, not Quickie 500 fast but faster than many of the sport models at the field. I'm thinking of building another one and putting my Magnum .61 2 stroke on it just for kicks........
Overall, the 4*40 is a very capable everyday sport flier that I hope to have around for a long time. It performs all of the sport manuvers I normally fly and the plane seems to take it all in stride. It is not, however, a 3D monster. If that's what you want, the 4*40 is not the plane for you but if you want a easy flying plane that loves dives, loops, rolls, ect..... the 4*40 may be just the ticket.
#83
ORIGINAL: GhostRider32
You sound fired up!
Congrats on the build and the maiden. The Sig Four Star series are awsome planes!
#85
I like it. Its a good easy flyer that's relaxing to fly. I can just sit in my lawn chair and fly the fuel away.
Yea, right!
#86
Hmmm, to fast ? Maybe you have to much pitch on your prop.Or maybe you CG is set some what forward?My favorite thing is to flip inverted right after take off and putz around at 1/3 throttle and flip it back upright just before I land .With a good headwind , itwell harrier invert ,at about a walk.
Try a few snap rolls, that well bring you out of your lawn chair, lol. Your right, they aren;t3D machines but one heck of a sport flier and a great addition to one's fleet . You done a really nice job on your build, Enjoy
#87
TX
Not too fast, just faster than I expected it to be. Not as fast as my Twist .40 with a Tower .75 2 stroke. That gave a new meaning to unlimited verticle.
#91
TX
Gary or SIC,
I'm going to La Porte, Tx in a few weeks and need to find a flying field to visit for a couple of days, know any in the area that would let a fellow AMA member fly a couple of days?
#92
Not sure, so I pulled this up.
http://www.modelaircraft.org/clubsearch.aspx
EDIT: I didnt take my zip. Plug in 77082 and within 50 miles.
#93
ORIGINAL: ScienceisCool
Can we do later that day? Going to a hockey game and a bar Saturday night. Or Monday works too since it's MLK day.
#94
TX
ORIGINAL: GaryHarris
My only chance will be in the morning up untill about noon.
#96
I can't give you a definite yes, but if I can drag myself out of bed I'll try to be there before 11.
If the weather holds up, Ill be there.
GR32, when you come down south, check us out on the west side of Houston.
#99
ORIGINAL: Zapped
Gary, you have mail! Does that bring back old times>
Mark, Performance Raceway when Jorge moved the onroad track indoors and I had all that new Trinity gear from my sponsorship. And if I remember correctly, I was dominating 1/12th scale.
Dude, I miss that track. K&M is gone. Area 51 is gone...
Thanks for the flashback bro!
Edit. I did a little photoshop on the pic. I had that cyst removed.
