What's going on the board this season?
#52
RE: What's going on the board this season?
ORIGINAL: barndawg77
Building my first kit this winter, a sig Mid star! I plan on using an Evolution 60nx for power, and I plan on adding a cowl and bigger control surfaces, thought about adding flaps and trying to make a STOL plane out of it...
This plane is soooo much fun with a 60 on it!! This was my second plane. Completely unlimited with a st G61 on it!!
#53
Finishing up an AMR 33% Waco(see below) and will then be starting a Curtis Jenny from Proctor plans blown up 200% to 33% scale with a span of 174.5", I like BIG planes
Anthony
Anthony
#54
MI
I have a couple kits ready to go, but I think it will probably be the Sig Citabria. I have been wanting to build this kit for a while, this Winter just might be the right time to start.
#55
ORIGINAL: biam
fjmeyer3638,
in what manner is balsa used to construct wind farms?
fjmeyer3638,
#56
ORIGINAL: fjmeyer3638
The impeller blades on the wind turbines are largely balsa. Our beloved wood is in its most heavy demand outside our hobby. You can look up construction methods many places and there is a move to use only composite materials - but most farms our company has been involved with (and there are a LOT) still use balsa as a framing material which is then covered in fiberglass, plastics, etc.
ORIGINAL: biam
fjmeyer3638,
fjmeyer3638,
#57
