Balsa USA 1/4 Sopwith Pup build
Reply
Old 01-13-2012, 06:35 PM
  #201
senrak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Balsa USA 1/4 Sopwith Pup build
Don't neglect that re-inforcment. It will break without it. I don't know why BUSA doesn't include it on the plans.
DW
senrak is offline
Old 01-13-2012, 06:53 PM
  #202
KDBrown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Senrak, I am also plannng to reinforce the elevator. I like your piano wire idea. What method did you use to attach the wire? Epoxy, wrap, etc.? I am planning to use one (1) Hitech HS-625MGservo for the elevator. Any pictures of your reinforcement?
Thanks!
Kevin
KDBrown is offline
Old 01-13-2012, 07:36 PM
  #203
senrak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kevin,
I put a v-grove in the leading edge of the dowel to hold the wire I glued hard balsa into the inboard corner of the elevator halves and drilled holes for the bent legs of the .093 wire. I used epoxy to weld everything together into a solid unit. I would post pictures, but the work has all disappeared under covering and paint. A picture would be worth a lot of words right now.
DW
I'll answer any question the best I can.
senrak is offline
Old 01-13-2012, 09:27 PM
  #204
KDBrown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Iknow just what you described. Will do the same.
KDBrown is offline
Old 01-14-2012, 06:09 AM
  #205
gervaisd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good day all!
My last project was the Sig Piper Cub 1/5th scale. Their procedure for the elevator is well done and very strong. Hope it could help.
Daniel
gervaisd is offline
Old 01-14-2012, 09:05 AM
  #206
CanDo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think BUSA got it right with the elevator joiner. For what it's worth, I've been flying my Pup for ~5 years now with no elevator failures. If you fly this plane like a scale WWI war bird, you won't have any problems.
I will caution you about one thing though. If you use push rods for the elevator and rudder, make sure you support them about every 5 or 6 inches. If you don't, they will vibrate and look like banjo strings. Ask me how I know!
CanDo is offline
Old 01-14-2012, 11:14 AM
  #207
senrak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How do you know?
senrak is offline
Old 01-14-2012, 01:56 PM
  #208
3136
3136's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: CanDo
....Ask me how I know!
OK how do you know?
3136 is offline
Old 01-14-2012, 02:00 PM
  #209
3136
3136's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just tried to order a barnstormer pilot from here http://www.hppilots.com/main/page_pr...ull_body_.html
But the store said his supplier doesn't do those mouldings anymore. Pooh[]
Any suggestions for a full body pilot?
Regards Mark
3136 is offline
Old 01-14-2012, 04:07 PM
  #210
Tx_RcFlyer
Tx_RcFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used this guy in my pup. And the price was even better!
http://www.horizonhobby.com/products...ub-arf-HAN4566
Tx_RcFlyer is offline
Old 01-14-2012, 04:19 PM
  #211
DougB1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: RCGARY
Good tips. Thanks.
I have a G26 in my Nieuport and it seems to be the perfect motor. I am planning on using the same motor in the Pup.
I have the BUSA Pup and used the G-26 ( mag. ) and still had to add a little weight and it has more than enough power to pull the Pup. I fly about 1/2 throttle and if I want to do a loop I only have to go to 3/4 throttle, wide open is WAY to fast and just doesn't look or sound scale. It is a blast to fly, lands very smoothly, and will float a long way if power is lost ( gotta remember to set the timer LOL )
Doug
1/3 BUSA Fokker DVII
1/4 BUSA Sopwith Pup
1/4 SR Eindecker
GreatPlanes Ele. Spad
DougB1 is offline
Old 01-14-2012, 04:41 PM
  #212
Muskoka dad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW WE MADE THE HOME PAGE, A FIRST FOR THIS BUILD[X(]
  SO I AM ONLY GOING TO USE ONE SERVO FOR THE ELEVATOR. WILL SHED A LITTLE WEIGHT.   ALSO STARTED COVERING THE
  TAIL FEATHERS AND EILIRONS LAST NIGHT.  I AM USING 21ST CENTURY FABRIC AND ITS GOING GREAT.  MIGHT START THE WINGS
  TOMORROW IF ALL GOES WELL. HOPE EVERY ONE ELSE  IS ON TRACK FOR SPRING MAIDENS.
   LATER  EWAN
Muskoka dad is offline
Old 01-14-2012, 05:04 PM
  #213
DougB1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Muskoka dad
LATER EWAN
Post some pictures as you go along if possible, like to see work in progress. [sm=wink_smile.gif]
DougB1 is offline
Old 01-14-2012, 05:28 PM
  #214
CanDo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3136, "How do I know?"
When I looked down into the cockpit while the engine was running, I noticed the elevator and rudder push rods were vibrating like crazy. I added horizontal supports where the fuse already had vertical supports. Then I slit some tubing lengthwise, put it over the push rods, and glued the tubing to the horizontal supports. Note, I did this mod AFTER the fuse was covered, I recommend doing it before!
BTW, I have an old US25 (25cc engine) with a 18x6 prop, and it has plenty of power at 1/2 to 2/3 throttle.
CanDo is offline
Old 01-14-2012, 06:22 PM
  #215
jameighan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Members,
This is just a general post in reference to the 1/4 scale Balsa USA Sopwith PUP. Many of my fellow club members have been flying the 1/4 scale PUP for the last 10 years or so.
I decided to increase the size of the PUP from 25% scale to 28% scale which yields a wingspan of 86 inches with 2500 sq inches. It required a cowl diameter of 10 inches due to the size of an ENYA VT-240 engine swinging a Classic 20-8 prop. I also pushed the firewall out another 2 inches to accomadate 2 fuel tanks and batteries for airborn gear and keep-alive for the glow driver. What got me started was I found 10" aluminum stock pots on sale at a local Wal Mart and that was a perfect fit for the Enya VT-240. The 9 inch cowl utilized on the 1/4 scale pup was a tad too small.
My son also built the 28% Sopwith PUP and he powered his with a Brisson 2.4 swinging a 20" prop. I had many photos of both of these planes and lost them due to a system crash. I should have backed them up. Such is life.
Both of these PUP's are not true scale, but the workmanship was good and when in the air they handle well even in moderate wind. My PUP weight was 24 pounds and my son's was about 21 pounds.
Many members in our club are building and flying WWI models and it's fun to fly the course with 7 or 8 in the air at the same time. It's like watching real gray-scale WWI dogfight footage, but this time it's in color.
Visit our club at www.mcrcs.com and check out the WWI videos.
Jim Meighan
jameighan is offline
Old 01-14-2012, 08:02 PM
  #216
FireBee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice video and a Halberstad. See www.militaryaviationmuseum.org as they fly a restored full scale. Our club is also doing a lot of WW-1!
As to Pup, My neighbor finished his and I did the maiden. What a blast. Particulars are: Zenoah g-26, Xoar 18-6, Dubro wheels and solortex olive drab. Scale flight is less than 1/2 throttle, add power to do a loop. CG per the plans. Make sure to use rudder in the turns. I set up a mix on a switch for 18% rudder with the ailerons to help make it easier. Flip off for loops, take off, landing.
Check out Warbirds over Delaware, couple years ago they set a record of 34 warbirds at half time show. This past year 26. Our club had 6 participate, two were Pups. It was like flying bumble bees everywhere. Best fun in years.
FireBee is offline
Old 01-15-2012, 12:07 AM
  #217
3136
3136's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Tx_RcFlyer
No offence mate but that pilot looks like a tranny with a bad spray tan, not that there is anything wrong with that
I don't mind spending $50-$100, surely there must be some decent pilots available,
there are heaps of bust ones but I can't find a decent full body pilot.
Regards Mark
3136 is offline
Old 01-15-2012, 01:12 AM
  #218
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 3136
Regards Mark
Just an idea . . . .
Have a look in a toy store at some boy friends of Barbie the Mattel girl.
Perhaps Barbie herself could fly your airplane .
Zor
Zor is offline
Old 01-15-2012, 10:40 AM
  #219
Tx_RcFlyer
Tx_RcFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No offence taken. We're all entitled to our own opinions.
Quote:
ORIGINAL: 3136
Regards Mark
Old 01-15-2012, 10:42 AM
  #220
Muskoka dad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HEY DOUGB1   I HAVE LOTS OF PICS, BUT CANT GET THEM OF THE CAMERA ONTO THE SITE.  I EVEN HAD MY WIFE HELP AS SHE IS
 MORE EXPERINCED WITH THAT.  IDONT GET IT  WE CAN UPLOAD PICS EVERYWERE ESLE.
 ANYWAY  OF TO START COVERING THE WINGS.
  LATER  EWAN
Old 01-15-2012, 03:07 PM
  #221
KDBrown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Ted,
In the process of mounting my DLE30 in the Pup. What size standoffs did you use? Or did you do something else? The standard 60mm standoffs are definitely too long, and I see online that there are 30mm standoffs available. I am also plannng to cut a hole in the firewall for carb clearance. Are your mixture screws still located on the front side of the firewall, or do you get to them on the back side?
Kevin
KDBrown is offline
Old 01-15-2012, 03:31 PM
  #222
DougB1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LATER EWAN
Well keep trying ,we'll be right here. [sm=spinnyeyes.gif]
DougB1 is offline
Old 01-15-2012, 04:00 PM
  #223
Tx_RcFlyer
Tx_RcFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kevin,
I custom made my standoffs. Not sure on the length. My mixture screws are on the backside of the firewall. A real PITA! I'm looking for parts to convert to a side carb as I have recently had carb issues and It is not user friendly to get to everything with my current setup. If I had to do it over, I would not worry about getting a more scale look and live with the extra length on the nose just to make maintenance easier.
Old 01-15-2012, 07:59 PM
  #224
5blue
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone have photos of pull pull elevator configuration for there Pup - really don;t want to use a push rod - for the elevators and would like to have individual elevator halfs - just for fun along with pull pull for rudder
5blue is offline
Old 01-15-2012, 09:47 PM
  #225
KDBrown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Ted,
I was looking at the engine, cowl, etc., and was also wondering if it is worth recessing the engine for a more scale look. I would sure like to. Perhaps installing a couple of access holes on the side so that I can get to the mixture screws. Maybe somehow cover these with the scale access cover plate. May need only one hole since the screws are side by side. I think the choke and throttle connections will be ok. I may order the 30mm standoffs and give it a shot. This will set the engine back 1 3/16" What do you think?
Kevin
KDBrown is offline
Reply
Display Modes
