Kits?
RE: Kits?
ORIGINAL: stumpffy
what if the plane has a fiberglass cowl or a molded canopy? And how do we preserve these parts in the kits that we buy?
If you have a canopy then fill it up with the rock hard plaster of paris. Support the canopy (not cut free from its carrier flange) when you do this. When dry, pop out the plaster 'canopy' and you have your 'plug'. You may need to build up the base to level it before 'pulling' canopies from it. The canopy is only as smooth as your plug so finish it as you like.
If you don't have a canopy then carve one from blue foam using the template method. You can either add framework (if needed) to your plug or you can pull another canopy on top of the first to be used as the framework. That's it in a nutshell- good luck! ARUP
CA
RE: Kits?
One thing to keep in mind is that many of the kits that were sold back in the day never got built! Now you can find them on Ebay. In the last few months I've picked up a Jemco Corsair for $77, Jemco p-47 for $140, Royal Corsair for $275 and an old Top Flite red box P-40 for $135. I also see many Bridi, Goldberg, Sig and others up for auction quite often.
