HELP WITH ST. CROIX/CRESSLINE LONG EZ KIT
#52
NY
RE: HELP WITH ST. CROIX/CRESSLINE LONG EZ KIT
Hey Saul, I've got the everything out of the fuse and started making changes to accommodate a servo less retract. I haven't worked on the servos in the wings, etc. Unfortunately I haven't worked on it in a while. Just didn't find the motivation this past winter. Now I'm fixing crashed planes and helis that I fly frequently.
Any progress on your Long EZ?
#53
My Feedback: (23)
No. I've been taking the time to build my cadre of ARF's that have built up over the years. Look what I found though:
http://ak-models.com/mm5/merchant.mv...de=NITRO90_160
Saul
Saul
#54
Just completed my second abortive flight, need some help before I fix it again, first flight was at full up stick, just to maintain altitude, as soon as I reduced throttle it cam down, fixed, added 2 deg incodence to the canard and applied a gap seal. rechecked C.G. and it is exactly where the plans have it, not the 1/8" ahead as the text recommends, this time it took off on its own and I didnot have enough down to keep it from climbing at full throttle, reduced power and guess what, nosed down and did not have enough elevator to pull out. had contorl throws that matched the plans, also started with .25" more elevator width. open to reasonable suggestions. set up is a G force .46 electric on a 4S 2200mAh Lipo
#57
I bought a 1994 St Croix/ Cressline Long-Ez 62.6 " wing span at a club auction. It has a poor but workable set of plans (legal size sheet copies that have to be taped together) but is missing the instruction booklet. Does anyone have or know where I could get a copy?
#61
St. Croix / Cressline 1/5 scale Long-Ez
My wife finally figured out how to add an attachment to this forum and added the attachment of the instruction booklet for the 62.6" wing span Cressline Long-Ez for anyone who needs a copy. The attachment is in my post just before this one.
Steve
Steve
#62
NY
Saul
Saul
#63
In need of Cressline Long EZ #2 sheet plans
I just received a Cressline .46 1/5th scale Long EZ from a friend about half built. Have the #1 plans and instructions booklet but not the #2 plans. Anyone out there willing to copy theirs for me. I would gladly reimburse costs. Thanks
#64
LongEZ plans
If so send me a private message with where to send it to.
Steve Ellis
