ACE RC 4-120 BIPE KIT BUILD
Hi Guys,Let's build a classic kit!!!With your help of corse.Want to do a few mods,4 servos in wings,a rounder tail,add some N struts,bombay doors.Ribs are not crushed, but need help to fall out,nice wood so far.Working on ribs tonight,will get the glue out tomorrow.Any build ideas will be valued,the first of pics.I know we all like lotsss of pics LOL. Thanks Les
Kpchilson (02-03-2023)
RE: ACE RC 4-120 BIPE KIT BUILD
Hey Cherry, I looked at the ACE website and I guess your bipe is a classic. I do not see it offered anymore. I am dyin to get m,y hands on a largish bipe kit. I would love to build the 33% Waco from AMR but it is around $1800 for the kit. My wife would lose it, and me if I spent that kinda money without taking her to the islands first. And unfortunatly for me I cant do both.
So, if you know where I can get my hands on another of those kits please let me know. And keep the pics coming brother. It looks good so far.
BC, CANADA
Looking good,I have this same kit new in box I acquired some years back,even have the modification plans published by R/C modeler,looking forward to following your build.
Hi Guys,Thanks for the good word,Man is the wood in this 30 year old kit is sweet!!! Spruce spars are straight as an arrow,Balsa nice and firm.Well got a good dry fit,CAed the ribs and top spars,got wing mount plate epoxed in.Traced out some rib templets need to cut out 4 to get N struts mounted.I can't beleive this big plane did'nt have them.Ok a little more sheet and leading edge,sheer webs are cut to havent tryed them yet maybe not much trimming.Well break is over back to work.Thanks Guys more pics
Hey Guys,Slow start today,sheer webs done,leading edge done,after lunch I'll get 3 small spars glued in and more pics.Hey stevenmax50,This is a ACE RC long out of buessnes,There was one on ebay the outher night.Well off to get some chow. Les
Hey Guys,Got some more pics!!After 3 small top spars,flip wing over and put front mount plate in with 30min epoxy.Then finish sheeting on wing bottom.Now some sanding before trailing edge cap.Want to put a Saito 125 GK in it they are purrdy.Been looking for a good used one,It'l fit in a UnionVille 8' raidial beaver kit I have also.Ok time to make some dust.Talk later Les
Hi Guys,Trailing edge on wing half 1 is on,Puting servos out where bellcrank went.Drill holes in ribs for sevo ext to pass,Will beef it up a little in servo bay.Top wing has some diehedral built in,make a gauge to set root ribs.
Wing half #2 under way,ribs glued in and sheeting, spars installed.Both wing halfs make a long top wing 70",bottom wing will be 62 1/2".Well trailing edge is on wing half #2,mounting plates,and front sheeting is done.Need to put holes for servo ext to pass thru next to mount plate.Then finish sheeting top of wing,sand ends flush and install wing tips,Ok let's git r done!!! Thanks Les ps PINK FLOYD is jamming so time to sand.
Hi Guys,Got the 1st half of bottom about done,Trying something new on this build.The assembly manual wants you to spray adhesive on wax paper,then stick spars and sheeting down, no pin holes,works really good as long as you have lots of lead to hold flat.
Glue in ribs and top spars,was missing 2 small top spars 1/8x3/16 cut some out of pine,fit good,now I can finsh sheeting.These wings build fast,still have alot to do on them,wing tips,servo mounts,lots of sanding.This is going to be a cool old bipe!!!Well the last wing half is dry fit now,time to glue.More pics. Les
Hey Guys,Got all 4 wing panels done,now wing tips,servo mounts,N strut mounts.Not going to glue wing panels together yet,takes to much room.The fun stuff is yet to come,soldering cabine struts,never done that stuff yet.Well some helpful hints would be good.Pics of wing tips tomorrow.Thanks Les
Hey Guys,This stuff took some xtra time.Wing tips are done,wing tips are 1/8" ply, after gussets I put a 1/4" band of balsa around edge top and bottom.Did them thing on my Sig Hog bipe,makes the tips a little thicker,easer to cover to.Boxed in new servo bays,cut some 1/8" ply servo covers got them all fit,put 1/4"sq hardwood around bay to screw covers to.A little more custom work to do then back to the manual.Bottom wing has more diehedral than the top,so some N struts will be fun to fab.Well back to work. Les
ORIGINAL: stevenmax50
I have a bipe on my watch list on ebay. It probably will go over my limit be a guy can hope cant he?
So Cherry, I have done alot of soldering over the years. To solder cabane wiring you will need a very hot iron. I recently bought a mini propane torch from Lowes. I used it to heat a nose gear wire so I could bend it. It gets plenty hot. And fast. An electric iron will work but I liked the propane torch alot better. Instant heat exactly where I need it. You also need to use silver solder. It can still have a percentage of lead, but the less lead the better. It obviously costs more but it is worth it.
Thanks stevenmax50,that is exactaly what I have,we soldered some landing gear for my floats a couple weeks ago,came out prety good.I have to clean wires yet will solder tonight.Thanks for the info,need to get pics caught up to where I'm at on build.Thanks Les
Ok Guys,this gets us caught up to where I,m at on build,make a two peice wing into one,got 1"total diehedral in top wing,30min epoxy
wing halfs together.Kool a 1 peice wing 70"span,laid 2oz fiberglass mat on center of wing overlaping 1",used 30min epoxy,laid a 1 1/2"
band of fiberglass tape down center,used finishing resin over all that,removed excess with card.Alittle mocf up,good size plane.
Thanks Les
Thanks Les
