*** Ultra Sport Brotherhood ***
Reply
Old 10-24-2012, 10:21 AM
  #1876
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: *** Ultra Sport Brotherhood ***
Do you by chance know what the useful prop range might be for the OS160fx? Trying to determine if there might also be a problem with the ultrasport installation especially with retracts. Thanks, Rich.
richwill11 is offline
Old 10-24-2012, 10:22 AM
  #1877
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry I meant to say prop ground problem.
Old 10-24-2012, 01:04 PM
  #1878
KaP2011
KaP2011's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aerobatic: 15x12-14, 16x10-14, 16.5x10-13
Sport: 17x10-13, 18x10-12
Straight from the OS web page.
KaP2011 is offline
Old 10-24-2012, 01:33 PM
  #1879
72
72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
APC 18-6w or 16-8 3 blade.
72 is offline
Old 10-24-2012, 02:25 PM
  #1880
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With the 17 or 18" props on the os160fx, in your opinions do you think I will have adequate ground clearance for the prop? Or will I need to use taller main retract struts?
Old 10-24-2012, 02:50 PM
  #1881
72
72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd say you need about 1" of ground clearance when the airplane is sitting on its wheels and the tail is up and level- takeoff attitude.
72 is offline
Old 10-24-2012, 03:00 PM
  #1882
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, it might be tricky, but I'll check the plans and see if I can obtain an estimated ground clearance measuring 9" from the center engine shaft (for an 18" prop) to see how far above ground the prop tip would be using the stock mains and 3" wheels that might be built with the kit. Thanks for you help.
Old 10-24-2012, 06:30 PM
  #1883
72
72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just measured a set of plans I have and when the wing centerline is parallel to the ground - 0 incidence -  there is 9 1/2 inches to the prop hub. A 16 inch prop would give you 1 1/2 inches clearance.
72 is offline
Old 10-24-2012, 07:13 PM
  #1884
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How bout that; we're spot on! I measured also using the same technique and got about the same. The plans said to use 2 3/4" inch wheels for retracts. So when I measured from the engine centerline to the line for ground on the bottom of the wheel, I got about 9 1/2" too. So a 18" prop wouldn't give enough clearance, but the 16" give about 1 1/2". So then I checked the APC web site and they offer 16" props starting at 3" pitch all the way up to 16" pitch. Then I downloaded the manual for the engine from the tower site and it calls for several 16" props and one 16.5" prop for aerobatic use. It also lists a couple of 17" and one 18" prop for sportsman use. So now I am happy and excited, because I think I can get the 160 installed OK. This engine didn't exist back in the 90's, weighs less than the ST2500, and is about the samesize as the os108 and puts out 3.7HP! Also took measurements from the motor mount and engine from the tower site and measured the plans, and it will fit nicely. So my winter project is laid out.
But gotta also figure out the retract install.
BTW, I'm planning to use an os engine mount, but it doesn't have any vibration isolators. I saw Jtec's snuff vibe kit, but wasn't impressed because you have to drill out you new motor mount to use it. Do you know of any other vibration mounts that are popular? Thanks, Rich
Old 10-24-2012, 07:50 PM
  #1885
72
72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If your prop is balanced and the firewall is solid, you won't have any problems. I am using the OS aluminium predrilled mount for mine. I have found the Xoar props are almost always balanced or require very little to get them that way. My favorite props lately are the Falcon props. I use these on everything up to a DLE111 and I have only had maybe one out of around 15 that needed any balancing.
72 is offline
Old 10-25-2012, 12:26 PM
  #1886
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info. Am not familiar with Falcon and Xoar,but will check them out.
Old 10-25-2012, 01:21 PM
  #1887
72
72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are the Falcons. He also has the Xoar's. I like the Falcons myself but have both.
http://www.thunderboltrc.com/index.p...2s1bgjli1kipf3
72 is offline
Old 10-25-2012, 02:24 PM
  #1888
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow! This is fascinating stuff. Thanks for letting me know what's available. Seems I will need to know how to determine the correct pitch prop for my 160 engine. Other that trial and error, is there a process to determine your engine requirements for a new engine? Have you started building your 1000 yet? Also, do you want me to address you by your first name our just #72? Jus thought I'd ask. Rich
Old 10-25-2012, 03:05 PM
  #1889
jrf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Richwill:
The best way to get the right prop to start with is to find out what other people are using. Do NOT go by the OS prop recommendations. They are intentionally oversized to keep the rpm, and therefore the noise, down for their European and Japanese markets. You will get much better performance and a lot lower operating temps by using the 18 x 6W or 16 x 8 three blade mentioned above.
Jim (My OS 160 fx has outlasted three airframes.)
jrf is offline
Old 10-25-2012, 05:16 PM
  #1890
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Jim!
Old 10-25-2012, 06:20 PM
  #1891
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim, who makes the 16/8 3 blade?
Old 10-25-2012, 06:40 PM
  #1892
72
72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rich, Mezjlik andZoar are 2 companies that make 3 bladed props. They are not cheap!!
I haven't started mine yet and won't until my house renos are done. Probably around Christmas. I have had 2 Ultrasport 60's which were each over 20 years old before they finally met their end.    Lash
72 is offline
Old 10-26-2012, 02:59 AM
  #1893
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Graupner, Master Airscrew are a couple others on the 3 blade props.
AJsToyz is offline
Old 10-26-2012, 07:40 AM
  #1894
jrf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Master Airscrew makes a 16 x 8 and a 16 x 10 three blade. They are not the most efficient props in the world, but the 160 in a US 1000 does not need to struggle to get the last few %.
Graupner makes 16 x 8 three blade that is more efficient, but expensive. (Google "graupner prop")
Jim
jrf is offline
Old 10-26-2012, 10:42 AM
  #1895
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the other prop sources, guys. Lash, I won't be starting mine til around the same time or after the first of the year. I mainly want to do the research to make sure that the upgraded components that I want to use will work, and I've found that they are. Can someone comment on what prower range digital servos that I should consider. I'm thinking of Futaba or Hitec brands. Rich
Old 10-26-2012, 11:26 AM
  #1896
box car
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Read this before you get digital servos
http://www.rcgroups.com/forums/showthread.php?t=801545
box car is offline
Old 10-26-2012, 12:10 PM
  #1897
richwill11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks!
Old 10-27-2012, 06:23 AM
  #1898
pt19 flyer
pt19 flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi rcken
got a question for you.
on the list I an listed as #97 but on some of the replies, etc
I am listed as #98.
so which one is correct? I assume that since I am #97 on list
that it is the correct one.
thanks
pt19 flyer
pt19 flyer is offline
Old 10-31-2012, 09:12 AM
  #1899
AmishWarlord
AmishWarlord's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saw a US 1000 up for bid on ebay.
http://www.ebay.com/itm/Great-Planes...item1c2c9ed3bb
AmishWarlord is offline
Old 10-31-2012, 11:27 AM
  #1900
hrrcflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Rich,
I recently had an Ultrasport 1000 with an OS 160 FX. If you decide to go the analog route with your servo's, I used a Futaba 9202 on each elevator half, a 9202 on each aileron and a 9402 on the rudder. If you want to go the digital route, I suggest something in the same torque range. Personally, I wouldn't use a Hitec servo for a paper weight, but of course the choice is yours.
Good luck with your kit construction.
David
Oh BTW, I just remembered that Futaba doesn't make the 9202 anymore. So if you don't already have any, you will need to find an equivalent servo.
hrrcflyer is offline
Reply
Display Modes
