*** Ultra Sport Brotherhood ***
Reply
Old 06-05-2014, 07:33 AM
  #2276
Tango Juliet
Tango Juliet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It would require a bit of scratch building, BUT if you still wanted an IMAA legal Ultra Sport that would (should) still perform like the US60, you could enlarge the plans until you got the IMAA legal wingspan with the enlarged fuse and tail plane to match. I'm pretty well convinced that you can up-size/down-size this plan with no ill effects.
Tango Juliet is offline
Old 06-05-2014, 08:13 AM
  #2277
jrf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Very interesting idea!
Quote:
That is a great idea. Better flight characteristics and more room for a gas engine. The enlargement factor would only be 12% so you would not have to change any of the wood sizes. You could have the RCM plans blown up at Kinkos/FedEx, or use the kit plans and delete the last rib at the end of each wing.
What a great flying airplane that would be! Quick responses like the 60, and not as floaty as the kit 1000. I have a 1000 kit, but now you have me thinking.
Jim
jrf is offline
Old 06-05-2014, 08:21 AM
  #2278
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i helped a buddy elongate the fuse, way back so i cant remember exactly how much but i think it was in the 6 to 8 inch range.
we did this by tracing the slab sides of the fuse on a peace of paper then addyng the extra distence along the turtle deck line. then adding the rudder post line parallel to and same length as the original then drawing a new bottom line to bring it all togeather. cut that out of 1/64 marine ply (because the new slab side was longer than the balsa we could get) and laminated balsa, two layers with the joints above the wing and half way between the wing te and stab le) to make the new slab sides. then built it by the numbers.
flew ju like the us60!
Joe
paladin is offline
Old 06-05-2014, 08:29 AM
  #2279
Tango Juliet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think I would rather enlarge the plans than just elongate the fuse. But that's just my preference.
Old 06-05-2014, 10:45 AM
  #2280
jrf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The extended wing gave the 1000 an increase in span of 12% and about 10% more wing area, so in order to give the 1000 the same ratios of area and moments as the 60, you would have to increase the length of the fuse from the CG back by 12% to offset the span increase and also increase the total area of the tail surfaces by 10% to offset the increase in the wing area. That would give you an airplane basically the same size as the kit plane. It still wouldn't fly the same as the 60 because of the higher aspect ratio wing, but it would be close. Blowing the plans up 12% gives you an airplane that is 25% larger than the kit plane, and aside from the unavoidable effects of the larger size and weight, it would fly exactly like the 60.
A 25% larger Ultra Sport 1000 (US1250?) would give a few more engine options also. Moki 2.1....50cc gas...Saito 220? A 50cc gas twin with the jugs hanging out would be awesome!
Jim
jrf is offline
Old 06-06-2014, 03:55 AM
  #2281
KaP2011
KaP2011's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You guys are a bad influence. You've got me thinking of having my US60 plans enlarged by 12%. My wife is not going to like that.
KaP2011 is offline
Old 06-06-2014, 05:52 AM
  #2282
Tango Juliet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You're welcome.
Old 06-06-2014, 05:56 AM
  #2283
Danster_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool "I hate it when that happens"
OK, I have to share with the Ultrasport Brotherhood and post this, originally completed in 1993 and have flown it religiously every year since then, Never more than a weed hole or tip wing rash or so until now. I won 5th prize in the Monokote covering contest when I completed it, hence the magazine pictures. US40 kit with O.S.61 and Dave Brown retracts as a tail dragger. I kinda put her in a coma last evening doing rolling figure 8's and she is currently resting in ICU until I can get a canopy and 6 rolls of Monokote for its resurrection this winter if I can stand looking at it in pieces that long. Going with a .46 heli motor with a pitts muffler this time instead of the heavy extremely overpowered .61 but boy did she smoke along... It will live again! My oldest daughter is in the Tower magazine ad and is the mother of my grandson who witnessed my fail in the crash pics. 21 years flying this jewel, not too shabby... "It happens" when you fly 'em like you stole 'em :-) ... how do I find my Ultra Sport brotherhood number?
Name:	Model Aviation.jpg
ID:	2001619   Click image for larger version
Name:	Tower Hobbies.jpg
ID:	2001620   Click image for larger version
ID:	2001621   Click image for larger version
ID:	2001622   Click image for larger version
ID:	2001623   Click image for larger version
ID:	2001624   Click image for larger version
Danster_1 is offline
Old 06-06-2014, 06:42 AM
  #2284
Tango Juliet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bummer! I remember those adds. Congratulations on getting her published. Remember, rebuilding her will add some weight. You may want to consider an OS 55AX. A little more oomph than the .46, but not as hot as the .61 was.
Old 06-06-2014, 08:05 AM
  #2285
KaP2011
KaP2011's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default US 40 w/55AX
My Ultra Sport 40 with an OS 55AX is an awesome flying plane. The 55AX gives it more than enough power.
Name:	Das Ultra red on blue.jpg
ID:	2001642   Click image for larger version
Name:	Das Ultra and Patriotic Ultra.jpg
KaP2011 is offline
Old 06-06-2014, 10:53 AM
  #2286
Brooklyn Mike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well guys i found out that a evolution 33cc engine will work and fit just fine in my US1000 so this is the way i'm going when i build it.I will post as i go along.Mean time i will fly my 60 size which i had from back in 1997 its my favorite out of all my other planes.
Brooklyn Mike is offline
Old 06-06-2014, 01:43 PM
  #2287
RCKen
RCU Forum Manager/Admin
RCKen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am in the process of building a US 1000 for another RCU member. We're planning for a DLE-30 to hang on the nose of it. I've "installed" it on the plans and looks like there is going to be plenty of room for the engine to go in there. One of the nice things about having a gas engine is that I can now move the fuel tank whenever I want instead of directly behind the firewall. I'm planning on moving the fuel tank, as well as a smoke tank back into the fuselage to that it's a bit closer to the CG of the plane. The owner of the plane wants a tricycle retracts on the plane so moving the tanks is needed so that I have room to put the nose gear behind teh firewall.
Ken
RCKen is offline
Old 06-06-2014, 01:45 PM
  #2288
Tango Juliet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, I don't know if it's still owned by copy right, but if it's not, I would like a copy of the US1000 plans if anyone is willing to share.
Old 06-06-2014, 03:33 PM
  #2289
Brooklyn Mike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ken thats right didnt think of moving the fuel tank, it is better to move it back some ,I didnt think the DLE would fit also its cheaper then the evolution 33cc.
Tango i have seen a kit on rcu for $200.00 go to the buy and sell section and type in us1000 it still might be for sale
Old 06-06-2014, 03:35 PM
  #2290
Brooklyn Mike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tango the us 1000 kit is still for sale in rcu i just checked seen it there.
Mike
Old 06-06-2014, 06:15 PM
  #2291
Tango Juliet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, but I don't want a kit. Just the plans.
Old 06-07-2014, 05:41 AM
  #2292
mpieklik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not sure if this is what your looking for, but there is someone on ebay always selling US1000 plans...
mpieklik is offline
Old 06-07-2014, 05:46 AM
  #2293
RoyR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by Calvinman View Post
Hi Joe, No I just try to iron down or trim solvent down the point as best I can, sometimes they stay, sometimes not. I have in the past rounded out the point to about a 1/4 radius but I don't think this makes a huge difference.
You can see the trim solvent bleeds the color. Back in the 90's I used too wet out the entire strip with not much bleeding, not sure if formulation changes have made it worse or if some colors just run more than others. Here I used the windex method and sealed the edges with trim solvent.
Calvi
I have made some pretty detailed graphics with the windex method. I have a Tiger head on a 4 star 40 with tiny pieces of monokote trim that haven't come off in a few years of flying. Using the solvent, whenever I finish sealing the covering with an iron, I find I have good luck if I slightly wet a Qtip with the solvent and just rub it around the edges. The color doesn't bleed, and capillary action pulls enough solvent under to hold the Monokote.
RoyR is offline
Old 06-07-2014, 08:23 AM
  #2294
jrf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If an individual still has the Great Planes plans that came with a kit they can sell them to you. The RCM plans are still available at rcmplans.com, but I have heard that the current owner may not be filling orders at this time. Try asking him a question by email first to see if you get a timely answer. Of course if an individual has the RCM plans, they can sell them to you.
jrf is offline
Old 06-07-2014, 04:55 PM
  #2295
Tango Juliet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually, I have the US60 kit/plans. I suppose I could just up-size them into a usable IMAA plan if I really wanted a true Ultra Sport in a larger size.
Old 06-07-2014, 05:34 PM
  #2296
Calvinman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Roy R I will try that next time, I was using a needle to run a bead along the edge and it was probably too much.Calvi
Calvinman is online now
Old 06-07-2014, 08:53 PM
  #2297
jrf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are some differences in the construction methods designed to make the 1000 lighter and stiffer. Between that and increasing the wood sizes 30+%, you would come out heavier that way than you would by blowing up the 1000 plans and using the original wood sizes. But on a 25% larger Ultra Sport 1000, it shouldn't matter much.
Jim
jrf is offline
Old 06-08-2014, 03:03 PM
  #2298
box car
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did a 1000 plan increase of 10 or 20% I had foam wings made they came out to 92", one of these days I will have to start on it.
box car is offline
Old 06-16-2014, 10:05 AM
  #2299
RCKen
RCKen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is an US 1000 kit for sale in the Marketplace right now for very affordable price of $200. If I had any free cash I would jump on it like a duck on a junebug, but my wife just opened up an Yoga Studio so any free cash we have is pretty tied up. So anybody looking for an Ultra Sport 1000 kit, I'd jump quickly as this kit won't last long at this price.
Ken
RCKen is offline
Old 06-16-2014, 10:45 AM
  #2300
Tango Juliet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like you, my desires over run my expense account. I'll have to pass on it.
Reply
Display Modes
