What to do with warped plywood?
AZ
To all,
I recently cleaned out one of the corners of the hangar/garage and found a stash of plywood sheets I had forgotten about. They range from 1/16 to 1/4" and all are warped pretty bad. The 1/16 looks like it was wrapped around a damn coke can. Anyway, whats the best way to go about trying to get them flat again? Or is their one? Thanks in advance.
Stangevil29
Stangevil29
NY
RE: What to do with warped plywood?
You might try amonia and water solution; soak and weight it down for a week. It might hurt the laminating glue though. If no one comes up with a sure fire way this may work. Sounds like you have nothing to lose.
The ammonia/water solution works quite well - had the same problem with some 1/16" and 1/8" awhile back and they came out fine. Soaked both sizes for something short of a week, then laid them out and weighted them down HEAVILY for a couple weeks until they were dry again. No problems, and they were flat as an Ohio field.
Dave
Dave
