Ultra Sport 60
AB, CANADA
Ultra Sport 60
I'm finally dusting off the box and starting to build an Ultra Sport 60. I was thinking of putting an OS 91 FX in it that I have lying around. To much? Its the same physical size as an OS 61 FX. Also wondering if a 3 -blade prop would work so that I don't need to lengthen the landing gear very much. I plan on building it as a tail dragger.
Thanks for your help.
RE: Ultra Sport 60
If you are not in rush to start and have time to look around a bit, you might consider a different landing gear configuration. Before I started my US1000 build, I had seen one with the gear mounted to the fuse instead of the wings. I thought it looked better than the stubbier wire gear called for in the kit. One day at the club field I saw a guy flying an Ultimate Bipe that had neat looking gear. I bought from Great Planes a replacement gear set for the Ultimate Bipe and installed it at the rear of the reinforced tank compartment.
RE: Ultra Sport 60
I have a ST .90 on my U,S. 60. and it's overkill. for the plane. Going to switch to a ST.75 as the 90 isjust not needed and I think takes away some of the flyingstyle of the plane. Hard for me to explain , but the extra thrust is pulling the nose around and fighting the airframe. I,m not sure if I'm explaining it right , but it;s the first plane I have over powered , that I didn't like the extra power Weird huh?
