Micro Telemaster Gas Conversion
Like the size of the micro but am hooked on gas.
Thinking of installing a .061 2 cycle. Would it need stiffening? I think double the firewall, reinforce front of fuse with some epoxied on 1/64th ply and extend sheer webs on the wings.
Also want strip ailerons.
Thoughts?
Tom
Thoughts?
Tom
My Feedback: (14)
RE: Micro Telemaster Gas Conversion
ORIGINAL: noveldoc
Thoughts?
Tom
Thoughts?
Tom
Designed as an electric powered model, there are plenty of "holes" in the front that will require sealing if glow/diesel power is used. If you haven't considered a model Diesel, give the Davis Diesel Development conversion head a try. Fitted to a Norvel .061 with throttle will give you a truly great flying IC engine powered micro Telemaster with its quiet, yet strong, performance and excellent throttling. Any conversion head for a Cox .049 will fit the Norvel .061 perfectly.
Yes, it would need some stiffening, but sealing the front with balsa pieces will provide much of the extra strength needed. A little triangle stock around the firewall wouldn't hurt either.
I have all of the Telemasters except the Micro. I'm off to find a kit of the Micro right now. And yes, I have the throttled Norvel .061 and the Davis Diesel Development conversion head already. If you decide to go this way, tell him that I sent you. Good luck and good flying.
Ed Cregger
I have a G Mark .061. Never ran. But the diesel idea is intereting.
Good point too about reversing the lightening stuff. I think I'll laminate some 1/64 ply to the front of the fuselage. Guess I will have some weight to play with with no battery.
Tom
Tom
