OLD KIT BUILDERS, WHAT'S THIS KIT??(AIRTRONICS JETFIRE 40)
I have a some build pictures to post of a kit I recently acquired but thought I'd give 24 hours to see if any of you old guys(I'm one, also) recognize the kit. The plane was kitted as a tri-gear(nose wheel) plane but I changed it to a tail-dragger. Tomorrow I will edit the title and post more info and pictures, but until then, Any Guesses??
vpresley got the right answer in 53 minutes. It is an Airtronics Jetfire 40 with a couple of changes. Campgems, I believe the wing to be right-side-up. That was one of the important steps during construction that had the rib tops marked so one would not be inadvertently installed upside down. The picture you referenced was prior to final shaping of the wing tips. My changes from the plans starting at the front: 1) 2 1/2" spinner instead of the called for 2 1/4" size, 2) The kit calls for a 40 size motor but I had on hand an OS 46FX and an OS 55AX. The two motors are similar in size/weight so I went with the 55AX. 3) Nose wheel not used(prop clearance consideration) and main gear moved forward. Main gear wheel size is 3" instead of the 2 1/2" called for in plans. 4) I hate fuel tank compartments where the tank is installed from the receiver/servo compartment. I made a removable, magnet held top hatch above the tank for easy access. 5)HS 225 servos, http://www3.towerhobbies.com/cgi-bin...&I=LXN664&P=SM , used for the elevator and rudder. HS 82MG servos, http://www3.towerhobbies.com/cgi-bin...&I=LXTRE2&P=SM , used for each aileron and a HS 81 servo used for the throttle. 6)The battery is mounted in a removable holder in the fuse behind the wing to balance the CG. 7)A tail skid was used instead of a tailwheel for two reasons. Simplicity(the rudder stops on top of the elevator) and to keep the nose a bit higher for prop clearance. A tail skid turns out to be shorter than a wheel assembly. 8)The rudder was enlarged by about 50%. I figured I would need the extra help taxiing with the tail skid and if it is not needed in-flight, I will just put the rudder on low rate.
Seajay, I installed triangular stock on the fuse below the horizontal stab to increase the glued area. I will keep your advice about flutter in mind when it flies.
I've added some pictures of the finished plane.
RE: OLD KIT BUILDERS, WHAT'S THIS KIT??(AIRTRONICS JETFIRE 40)
Don't know what it is, but it sure looks like the wing is upside down. It looks like a semi symmetrical wing that is mounted with the shorter surface on the top vs the bottom. Could be the aspect view of the photos, but all three lead to the same conclusion. I would check it out before I Went any further on the build.
Don
Don
My Feedback: (162)
You might be right camp, but the blocks are still not carved and sanded all the way. The right one looks off, but the left one looks good ?
Vince
Don't know the kit, but love the looks! Just begs for a nice electric motor. Looks like she'd be fast and quiet! Tom
Yes, It's a Jetfire 40.. I built a beautiful one when I was 17, and crashed it when I was 18.. I had a Rossi .40 on it, and it hauled butt...
One word of caution, You need to re-enforce the Horizontal stab.. Maybe Using Carbon fiber strips, maybe a strip on the top from center Leading edge, out to outer trailing edge, and on the bottom from the outer leading edge, to center trailing edge, in kinda a criss cross fashon, if you were able to see both strips through the wood.. or even hardwood (Basswood, Maybe) on all edges.. the reason I say this, is because my plane was so fast that the trailing edge fluttered.. I had zero gap in the hinge line, tight servo linkage, etc. I had to run "Flying Wires" From the bottom fuse to the outer (2/3 the way out) horizontal stab, then up to the Vert stab, just to stop the flutter in the Horizontal stab.. then it still hauled Butt....
It was an awesome plane.. If I find a Picture, I'll post it..
Good luck. It's a great plane!!
Craig.
Craig.
ORIGINAL: vpresley
Vince
Vince
I've got to second the other comments on it looking like a kick mule plane.
Don
Gray Beard,
WOW, a 200 year old Kit.. is that a kit that you are given a log, then you just have to carve away anything that doesn't look like a plane, kinda like how the Native Americans used to make canoes??
Craig..
Craig..
Just a final post for this plane. Flew the maiden flights and they were non-events. A few clicks of trim and she flies really well. The prop clearance, or lack thereof, requires a perfect, on speed, smooth touchdown or the prop will hit the grass and the engine stops. How I hate walking out to get the plane
ORIGINAL: Campgems
Don
Don
My Feedback: (-1)
ORIGINAL: SeaJay
Gray Beard,
Craig..
Gray Beard,
Craig..
My Feedback: (67)
CA
OK, I gotta gripe; what is it with the side exhaust engine laying on its side with the muffler sticking out in the slipstream anyway? This guy needs a back door front breather with a pipe running along the fuse, preferably a stinger[>:]. BTW, nice ship.
ORIGINAL: Roary m
Roary M, I bought them for a Dave Platt Duellist MKII that I intended to build. But as time progressed, I decided my old eyes were not good enough for a speed demon like the Duellist. A fella out in Texas bought the kit and didn't want the motors. Just as well. They are great little motors. I have two YS-61s, one flying, and they are great motors, also. Really good when the tank can't be right behind and in line with the carb.
My Feedback: (67)
CA
Apart from the sheer power these things generate, I forget the pump makes the tank location less critical-good one there. I'm with you on the duellist with regards to the vision issues, I still have my kit and I'm hanging on to him as long as I can.
