great planes
great planes
i bought a supersposter 40 kit, it will be my first build. has anyone ever built this kit? can i get help onadvice to building a kit and theDOES and DONT'S about building kits?
RE: great planes
That's a great kit! Ask any questions you need and we'll help you out.
Start by reading this:
http://www.rcuniverse.com/magazine/a...rticle_id=1196
RE: great planes
the main thing i want to no is, IS IT AN EASY BUILD when i say easy i mean buildable to a good standard for the first time builder
RE: great planes
I'd recommend something like a Goldberg Tiger, Cub, or Four Star for a 1st build if you have experience flying.
The issues that would cause confusion on the Super Sportster are bending large planks of soft balsa with windex or ammonia, and the nose takes a lot of carving. The carving could frustrate a lot of people without come shaping experience. NOT saying this is the case with you, I just see it as a shortfall wanting to get your 1st build into the air. Whenever something takes a lot of time to produce, it becomes an exercise in lengths of patients. It is important the right tools be used.
The landing gear is another area to consider. It needs some extra strngth if flying off of grass strips.
My Feedback: (-1)
RE: great planes
I used the SS as a teaching aid for students first build for a long time. It really isn't a bad build at all, just follow the instructions and READ THE INSTRUCTIONS!!!! I have students take the instructions home and read them through three times before the glue ever comes out. Someone put me onto the 4*60 years ago and I started using that for first time builders but depending on the pilot I'm thinking of going back to the SS. I'm pretty sick of the 4* right now and the SS is a better stunt plane. That's why I mentione it depends on the pilots skills what plane I'm going to use to teach.
RE: great planes
ive built a sig monocoupe free flight and that turend out good and that was delicate soi have got some pashience lol.
Thanks for the help and the landing gear point.i will make sure to strenthen the gear or even mount one to the fuselage as the grass strip can get bumpy if the horses escape into the field.
My Feedback: (-1)
RE: great planes
ORIGINAL: broonzie 09
RE: great planes
it the supersporster heavy as the fusealage it thick sheet and none of the plane it ribs its all sheet balsa.
example: rudder all thick sheet
elavator all thick sheet
so wont that be heavy??
My Feedback: (-1)
RE: great planes
BANG!!!!!!!!!!!! I like my planes a bit on the heavy side, I live in a high wind area and the more stout the plane is designed the longer they last. My planes last for decades if I don't do something really stupid. Most of the light weight ARFs last out here for about 1 season before the air frame is shot. It's your plane and you can do with it what you want. You can buy and use contest grade wood and replace parts and sheeting. You can use 1/16th balsa when they gave you 1/8 or 3/32. It's up to the builder. I keep a lot of contest grade wood on hand in my shop and replace wood when I think it would be better then the kit supplied. It's isn't a light weight ARF, it's a plane that will last. Don't worry about the weight. Too many people have bought into the ARF thinking. Wood weighs more then air and there is way too much air in an ARF.
