Reload this Page >
SIG Ryan STA special kit by Maxy Hester
Old 01-08-2016, 04:04 PM
  #126
jwharkinz
jwharkinz's Avatar
Now that the holiday time has passed I'm continuing this build. I ordered Flite-Metal from Ed and he really delivered! Thanks for the awesome service, you rock!!
http://www.scaleaero.com/flitemetal.htm
I'll post some photos soon
Old 01-09-2016, 02:49 AM
  #127
thomasmuckus
thomasmuckus's Avatar
Hi John,
realy good news.
By the way, happy new Year for You and Your family, especially to Your nephew!
I send some pics from my exaust-solution
It creates a very deep and warm sound, not realy like a 4-stroke but nearly and even better than a single stroke.
Regards from Germany,
Thomas
ID:	2140441   Click image for larger version
ID:	2140442   Click image for larger version
ID:	2140443   Click image for larger version
ID:	2140444   Click image for larger version
ID:	2140445   Click image for larger version
Old 01-11-2016, 07:53 AM
  #128
FlyerInOKC
FlyerInOKC's Avatar
Interesting muffler system, refresh my memory what size is this engine?
Old 01-11-2016, 10:35 AM
  #129
TLH101
My Feedback: (90)
TLH101's Avatar
I just posted one these kits for sale in the RCU marketplace.
Old 01-12-2016, 01:34 AM
  #130
thomasmuckus
It is a OS 91 Surpass II, without pump, Master Airscrew 14 x 8
Old 01-16-2016, 08:56 AM
  #131
jwharkinz
jwharkinz's Avatar
Photos of progress.
I am going to attempt to video some of the application process, in the meantime...
ID:	2141769   Click image for larger version
ID:	2141770   Click image for larger version
ID:	2141771   Click image for larger version
ID:	2141772   Click image for larger version
ID:	2141773   Click image for larger version
ID:	2141774   Click image for larger version
ID:	2141775   Click image for larger version
ID:	2141777   Click image for larger version
ID:	2141778   Click image for larger version
ID:	2141779   Click image for larger version
ID:	2141780   Click image for larger version
ID:	2141781   Click image for larger version
ID:	2141782   Click image for larger version
ID:	2141783   Click image for larger version
ID:	2141785   Click image for larger version
ID:	2141786   Click image for larger version
ID:	2141787   Click image for larger version
ID:	2141788   Click image for larger version
ID:	2141789   Click image for larger version
ID:	2141790   Click image for larger version
ID:	2141791   Click image for larger version
ID:	2141793   Click image for larger version
ID:	2141794   Click image for larger version
ID:	2141795   Click image for larger version
ID:	2141796   Click image for larger version
ID:	2141797   Click image for larger version
ID:	2141798   Click image for larger version
ID:	2141799   Click image for larger version
ID:	2141801   Click image for larger version
ID:	2141802   Click image for larger version
ID:	2141803   Click image for larger version
ID:	2141804   Click image for larger version
ID:	2141805   Click image for larger version
ID:	2141806   Click image for larger version
ID:	2141807   Click image for larger version
ID:	2141809   Click image for larger version
ID:	2141810   Click image for larger version
ID:	2141811   Click image for larger version
ID:	2141812   Click image for larger version
ID:	2141813   Click image for larger version
ID:	2141815   Click image for larger version
ID:	2141816   Click image for larger version
Old 01-16-2016, 12:14 PM
  #132
jwharkinz
jwharkinz's Avatar
Here is a video of covering one section..
https://www.youtube.com/watch?v=-lRFztTjXZE
Old 01-17-2016, 10:05 AM
  #133
thomasmuckus
Cool work, Your video is really good.
A question > what is the weight of this stuff (gramm per square-inch), are there any experiences about resistance to fuel? And another question > in post 122 You wrote that You had changed the landig gear > are there any pics ?
Regards,
Thomas
Old 01-17-2016, 11:42 AM
  #134
stuntflyr
stuntflyr's Avatar
Both JW and Tomas models are looking great. Super job on the covering JW. Thomas' exhaust is just cool. Good job.
Chris...
Old 01-27-2016, 08:22 AM
  #135
jwharkinz
jwharkinz's Avatar
Now that I have successfully registered to return to school for some fabrication classes, time to knock out this plane for some late spring enjoyment! I am going to rework the landing gear and exhaust with some brazing. I'll be looking into the brakes design, now that I'm looking at my previous work, Yea, it needs to be redone! The exhaust is restrictive and so I plan to open it up and braise it together(thats the plan anywayz).
Old 01-27-2016, 12:42 PM
  #136
jwharkinz
jwharkinz's Avatar
just ordered the brakes and this is what i settled on
http://www.hobbyking.com/hobbyking/s...181&aff=965875
Old 01-31-2016, 06:27 AM
  #137
jwharkinz
jwharkinz's Avatar
Starting the process of rebuilding my exhaust system. First, I rolled some leftover aluminum computer case material around my mag light then used [h=1]aluminum brazing rod with a propane torch.[/h]
ID:	2144456   Click image for larger version
ID:	2144457   Click image for larger version
ID:	2144458   Click image for larger version
Old 01-31-2016, 11:46 AM
  #138
thomasmuckus
Looks fine, all my attempts for soldering aluminium failed, so I used thin steel sheet (0,3 mm) > the weight of the komplete muffler is 115 gramm. I hope Your`s will bee lighter.
Old 01-31-2016, 12:27 PM
  #139
jwharkinz
jwharkinz's Avatar
As I work to complete my exhaust i'm thinking of adding a smoke system. Iook's as if I can take advantage of the YS pressure system to drive a smoke system. I found this a schematic illustrating what looks to be a viable setup.
ID:	2144538   Click image for larger version
Old 02-03-2016, 10:17 AM
  #140
jwharkinz
jwharkinz's Avatar
I've been installing the new brake system for the past couple of days. These things look good, let's hope they perform as well. What I did do was re-engineer the bearing due to the fact the one it came with was a small unit that only supported the outer portion of the wheel assembly and allowed for wobble. It now has a full length carrier and full floating aluminum bearing. I also replaced the foam 3.5inch tires with dubro rubber lo-bounce 3.25inch tires. Here are some photos of the finished work.
ID:	2144993   Click image for larger version
ID:	2144994   Click image for larger version
ID:	2144995   Click image for larger version
ID:	2144996   Click image for larger version
ID:	2144997   Click image for larger version
ID:	2144998   Click image for larger version
Old 02-05-2016, 07:18 AM
  #141
jwharkinz
jwharkinz's Avatar
I'm working on the exhaust system, it's been a mild learning curve to this point. here's a look, there's more to go...
ID:	2145381   Click image for larger version
ID:	2145382   Click image for larger version
ID:	2145383   Click image for larger version
ID:	2145384   Click image for larger version
ID:	2145385   Click image for larger version
ID:	2145386   Click image for larger version
Old 02-05-2016, 07:35 AM
  #142
jwharkinz
jwharkinz's Avatar
here are some photos of the components going into this project, newer tech is so much fun...
ID:	2145388   Click image for larger version
ID:	2145389   Click image for larger version
ID:	2145390   Click image for larger version
ID:	2145391   Click image for larger version
ID:	2145392   Click image for larger version
ID:	2145393   Click image for larger version
ID:	2145394   Click image for larger version
Old 02-05-2016, 08:25 AM
  #143
thomasmuckus
Your exhaust system looks very nice (if I could work with alu just like You do....). I hope the temperature in it will be high enough for the smooker, when I tested my muffler I was surprised, cause the big volume it was not so hot (I don`t burn my fingers )
By the way, some pics from my landing gear solution. Your break system is very interesting but we have a grass runway so I don`t belive that I need one ( on the other hand > newer tech is so much fun...)
this are some pics from the original, the second is from my son as he visited California last year.
After that, I had to do some moulding work, I used the plasic parts as prototype (the same as I`ve done with the cowling).
It is still simply snaped together to see how it works > I`m satisfied, it need some fine-tuning but it works as well.
Name:	Fahrwerk Original 1.JPG
ID:	2145397   Click image for larger version
Name:	Fahrwerk Original 8.JPG
ID:	2145398   Click image for larger version
Name:	Fahrwerk Original.jpg
ID:	2145399   Click image for larger version
ID:	2145400   Click image for larger version
ID:	2145401   Click image for larger version
ID:	2145402   Click image for larger version
ID:	2145403   Click image for larger version
ID:	2145405   Click image for larger version
ID:	2145406   Click image for larger version
ID:	2145407   Click image for larger version
ID:	2145408   Click image for larger version
ID:	2145409   Click image for larger version
ID:	2145417   Click image for larger version
ID:	2145418   Click image for larger version
Old 02-05-2016, 10:01 AM
  #144
FlyerInOKC
FlyerInOKC's Avatar
Nice job on the gear!
Old 02-05-2016, 11:48 AM
  #145
jwharkinz
jwharkinz's Avatar
love the gear work, you just have to admire that great craftsmanship
Old 02-06-2016, 10:32 AM
  #146
thomasmuckus
Here I have some pics for You about Your "bright-polished-aluminium-version", I hope they will motivate.
Some from the www, some from my son. He visited Californialast year with his girlfriend and, cause he is a good son, he found a museum where was a Ryan hanging under the roof and so he`ve done some pics in some unusual perspectives. Enjoy
ID:	2145584   Click image for larger version
ID:	2145585   Click image for larger version
ID:	2145586   Click image for larger version
ID:	2145587   Click image for larger version
ID:	2145588   Click image for larger version
Name:	Fahrwerk Original 4.JPG
ID:	2145589   Click image for larger version
Name:	Fahrwerk Original 5.JPG
ID:	2145590   Click image for larger version
ID:	2145592   Click image for larger version
ID:	2145593   Click image for larger version
ID:	2145594   Click image for larger version
ID:	2145595   Click image for larger version
Old 02-09-2016, 11:47 AM
  #147
thomasmuckus
first set of lower flying whires added, now it works that I can with this gearsystem move and remove the weelpants without removing the flying whires
ID:	2146259   Click image for larger version
ID:	2146260   Click image for larger version
ID:	2146261   Click image for larger version
Old 02-09-2016, 01:12 PM
  #148
FlyerInOKC
FlyerInOKC's Avatar
Nice, you're lucky Max is gone he would want his plane back!
Old 02-17-2016, 06:47 AM
  #149
jwharkinz
jwharkinz's Avatar
I've been working on the fuel system and figuring out the "Horn Shoeing" of three tanks onto this hull at the preferred center of gravity, an approximate...
What I've figured is that I can get two 16oz. tanks in here with the 2oz. hopper. Now I need to test the smoke tank to be sure it doesn't melt. The fuel system will be tested and if I remember to I'll video the event(heh).
I removed the two magnets in favor of a mechanical latch.
Just received the final shipment last night and now its time to get this missile ready for launch...
ID:	2147973   Click image for larger version
ID:	2147974   Click image for larger version
ID:	2147975   Click image for larger version
ID:	2147976   Click image for larger version
ID:	2147977   Click image for larger version
ID:	2147978   Click image for larger version
ID:	2147979   Click image for larger version
ID:	2147981   Click image for larger version
ID:	2147982   Click image for larger version
ID:	2147983   Click image for larger version
ID:	2147984   Click image for larger version
ID:	2147985   Click image for larger version
ID:	2147986   Click image for larger version
ID:	2147987   Click image for larger version
ID:	2147989   Click image for larger version
ID:	2147990   Click image for larger version
ID:	2147991   Click image for larger version
ID:	2147992   Click image for larger version
ID:	2147993   Click image for larger version
ID:	2147994   Click image for larger version
Old 02-17-2016, 06:50 AM
  #150
FlyerInOKC
FlyerInOKC's Avatar
There is just something about a shiny aluminum airplane!
