Reload this Page >
Carl Goldberg Ultimate 10-300 Brotherhood.
Old 03-17-2015, 07:47 PM
  #1676
abbott915
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Waco, email sent.
I also want to thank others here at the "brotherhood" for their help in creating the file with the tracings, especially peternj who provided me with a lot of if not most of the info I used.
My project is coming along nicely, and am just doing the sanding and internal hardware before covering.
abbott915 is offline
Old 03-18-2015, 05:29 AM
  #1677
raubold
My Feedback: (156)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
removable Canopy, Goldberg ARF version, unless modified during building
raubold is offline
Old 05-05-2015, 05:52 PM
  #1678
jjoos99
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have three flights on my ultimate with my gas conversion. I installed a valley view rc 20 gas motor after removing a ys 120. I was afraid it might be alittle underpowered but it actually flys quite well. Nowhere as close to power as the ys but actually has pretty good vertical. I flew 3 flights for the same amount of fuel ad one flight with the ys but used $2.40 a gallon fuel instead of $20+ a gallon. I would like to try a different prop to see if I can pull alittle bit more performance out of it. I have my servos in the tail of my ultimate and with the 20cc gas motor I had to locate the battery all the way up front attached to the engine beam to get the right balance. Probably wouldnt hurt for the next size up engine for getting better balance and more power.
How much thrust angle is everyone running on theirs. I am having to add quite a bit of rt rudder to get a straight upline.
thanks
Jeff
jjoos99 is offline
Old 05-06-2015, 07:48 PM
  #1679
raubold
My Feedback: (156)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have a 17X6 XOAR on mine, IBEC with a A123 LiFe 6 OZ tank (no ignition Battery) came out lighter and performs as good as my OLD YS 120, have to mention that i hardly use full throttle at all vertical absolutely enough, horizontal i don't need to break the sound barrier or blow my control surfaces of, so its all cool
have a great one with it, no to glow
raubold is offline
Old 05-19-2015, 10:14 AM
  #1680
everwood
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone happen to have a set of Bluehawk decals laying around they they would want to part with?
everwood is offline
Old 05-19-2015, 05:05 PM
  #1681
J.Paul Saure
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do...
...but I'm a little away from you!!!
J.Paul Saure is offline
Old 05-19-2015, 06:15 PM
  #1682
everwood
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes you are. i'm afraid shipping would be prohibitive. Thanks anyway.
I'll wait a while and see if something else pops up. Hopefully someone out there has a set.
everwood is offline
Old 05-19-2015, 06:28 PM
  #1683
charlie111
charlie111's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just Cleaned of Bed! That was Parts Dept. Since XMAS! Finished Electric Self Rotating Rotarywing! You can see a Vid. of 1st Test Flight! Collar @ Base of Shaft Moved Set Screws Can't Bite on Hardened Shaft ? Not even a Scratch So, I'm Drilling Dimples for set Screws to Lock into! It won't Happen again! Shaft Dropped 1/2" Affecting Pitch Big Time! Wings look Tail Heavy in Video But, Balanced @ Chord Line Linkage Did That! 3 Contact Rings & Brushes Worked fine For Speed controls on Both Motors! Balsa with Boat Wrap Covering! See rotate1953 on Twitter or Charles Glazebrook on You Tube!
ID:	2097245   Click image for larger version
ID:	2097246   Click image for larger version
charlie111 is offline
Old 05-23-2015, 05:04 AM
  #1684
notruthless
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by charlie111 View Post
Just Cleaned of Bed! ...
Looks like you're on the wrong thread.
notruthless is offline
Old 05-23-2015, 05:10 AM
  #1685
charlie111
charlie111's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A Reason to Get an Exuast Fan in Window! I don't think it will Hurt you? In this Lifetime? Coal Miners got Black Lung!
Old 05-23-2015, 03:42 PM
  #1686
everwood
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If anyone is interested, i have an inbuilt kit that it looks like i will never get around to building. It seems to be all there. Even the Bluehawk decals.
I would sell it for $250 plus shipping.
By the way, i am still looking for a set of decals for one i am recovering and setting up with Dle 20.
everwood is offline
Old 05-25-2015, 03:53 AM
  #1687
cracker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are we still assigning numbers?
If so....I'll take the next one available.
cracker is offline
Old 05-25-2015, 08:16 AM
  #1688
charlie111
charlie111's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an Old Comet Kit I don't think I'll ever Build But, Had to Buy it Only Offer on Ebay See My Electric Self Rotating Wing on You Tube! Charles Glazebrook Needs a Little Tweaking on Mixing arms Neg. Pitch Overode Servo Wanted it for Autorotation I'll have to Make Custom Mixing Arm! Impressive Video!
Old 05-31-2015, 09:37 AM
  #1689
expertpc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello, I am new to this forum. I am trying to gauge the value and eventually sell an Ultimate 10-300 kit that I purchased about 20 years ago and only partially assembled. Any insight would be appreciated. If I should not be posting this here, I do apologize and would appreciate any guidance on where I should post it.
I am the original owner, no motor, mold or radio, just the complete kit. Can provide detailed pics if it would help.
ID:	2099729   Click image for larger version
ID:	2099730   Click image for larger version
ID:	2099731   Click image for larger version
ID:	2099732   Click image for larger version
expertpc is offline
Old 05-31-2015, 09:51 AM
  #1690
charlie111
charlie111's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just the Kit No Radio or Motor? I have Motor & Futaba Radio if your Interested? Busy Testing Project Only Out twice with it & had Small problems 3rd. Time's a CHARM So Watch for It! Over 6' Span But, Dropped 6-7 lbs of Landing Gear 4 3" Wheels & Rubber tires,Oak axles = Baseball Bat,Steering Likage Bellcrank & Servo,Boat Wrap over Balsa Removed. Last time out Neg. Held Neg. Overpowering servo! Made Better Mixing arms 3rd. Time's a Charm!I Think you'll get the Idea after seeing Videos?
Old 05-31-2015, 12:50 PM
  #1691
raubold
My Feedback: (156)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why are you creeping around in this Forum if you just have your funky propeller wingythingy to talk about ?? we don't really care about that
raubold is offline
Old 07-05-2015, 02:32 PM
  #1692
peternj
peternj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok gang, I know this thread is slow with activity. But I'm looking for help. Doinked my 23yr old ultimate today. Repairs can be done but the cabanes are bent up. Should I make new ones or straighten out the ones I got?
any help will be appreciated.
peternj is offline
Old 07-05-2015, 06:43 PM
  #1693
jjoos99
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not an expert but I would think if the metal doesnt look stressed you could repair it. Usually the metal will have a color change in the stressed areas where it might be stretched. biggest thing I would think would be making sure that the wing incidence is correct after the repair.
Jeff
jjoos99 is offline
Old 07-05-2015, 07:05 PM
  #1694
peternj
peternj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the info jjoos... The metal does not look fatigued so i should be able to use a vice to get it straight. The incidence will be re-checked as both the bottom and top wings will ave to be rebuilt. They could be repaired but it will be just as much effort if not more than cutting all the ribs and building new straight panels. The fuse is fine, suprisingly my re-enforcement for the cabanes for the ultimate build I did and applied to this one held and the metal bent instead, guess if it wasn't re-enforced than it would just broke off inside the fuse. Either way it's time to order some parts from fiberglass specialties and get this bird fixed up. Man I had it for 23 years without incident. And while I'm fixing this one I guess I'll finish off the spare one I framed up a few years back.
peternj is offline
Old 07-06-2015, 05:50 AM
  #1695
jjoos99
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that is fantastic you have been flying your ultimate for 23 years. I might have 8 on mine. converted to gas this past winter. I only got about 6 flights in this year and lost my private runway. I have been fortunate enough to have a runway a mile from my house but the farmer sold off the field and I will have to find a club to join. Worst part is the closest one is a 20 min drive. I guess I have been spoiled. Good luck with your rebuild.
Jeff
jjoos99 is offline
Old 07-06-2015, 06:15 AM
  #1696
jescardin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dear Friends,
I would much thank you add me to the CG Ultimate 10-300 Brotherhood as I own and fly a ARTF version since 2006.
I bought it second hand from a clubmate and originaly powered it with an OS 1.20 Four Stroke, which have given outstanding service for years. In 2012 I though it will benefit from a little more power and unsuccesfully tried a JBA 140 which even damagen fuselage top wing strut due to vibrations. At the beginning of this year finally installed and runned in an OS 1.20 Two Stroke which gives both power and reability to the flying.
I enclose a flying photo still with the OS Four Stroke and you may read further details in this other thread devoted to our beloved machine:
Goldberg Ultimate 10-300 build
Best Regards,
Jesus Cardin
Name:	CG Ultimate.jpg
jescardin is offline
Old 07-06-2015, 06:14 PM
  #1697
raubold
My Feedback: (156)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have a set i do not need, let me know pm me
raubold is offline
Old 07-06-2015, 06:24 PM
  #1698
raubold
My Feedback: (156)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
only one good, the other is not usable
raubold is offline
Old 07-06-2015, 08:06 PM
  #1699
abbott915
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I made new cabanes for my project by getting some 1/16th inch thick 5052 aluminum and they cut them into the correct width for me.
Post #61 at this link:
http://www.rcuniverse.com/forum/kit-building-121/11589743-carl-goldberg-ultimate-10-300-build-3.html
Old 07-07-2015, 09:34 AM
  #1700
mattnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My original Ultimate has been doinked about 5 times over the 20 years or so I've had it... each time I just straightened the metal out and remounted the wing... never had a problem and it always flew as it had before...
mattnew is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
