RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Kit Building (http://www.rcuniverse.com/forum/kit-building-121/)
-   -   Sig Hog Bipe Beginner (http://www.rcuniverse.com/forum/kit-building-121/10921883-sig-hog-bipe-beginner.html)
shepard62 01-22-2012 02:26 PM
1 Attachment(s)
Oh the mistakes! Even before I started with the CA , I pulled the wing ribs out of their sheets and cleaned them up with sand paper. The next instruction was to glue in place and be sure the tab(the one I just broke off) is touching the work surface. See the blue tape on the bottom of each rib, yep taped back on for the position required.
OK here is the question. The CA wheeze is coming back after only a few hours of glueing WITH a respirator. So on to the Titebond II. What is the reccommended dilution for this stuff? one to one as I need to get into some tight spots.<br type="_moz" />
aymodeler 01-22-2012 04:43 PM
RE: Sig Hog Bipe Beginner
Have you tired any of the odorless CAs? I find that the regular stuff makes my eyes burn but the odorless stuff is fine. It's usually a bit more expensive, but still a small part of the total build cost.
aymodeler 01-22-2012 04:44 PM
BTW, I'm looking forward to your build! I have had my eyes on doing a Hog Bipe for a while now.
SeamusG 01-22-2012 04:54 PM
No dilution of Titebond needed. Just keep it to a minimum - wipe with the ole finger and what is left is enough. It takes a couple of hours to tighten up nicely. I have q-tips and a cup of water at hand to clean up any excess outside of the joint.
BTW - we all use blue painter's tape to put the tabs back on the ribs!
Shameless reference to my own Hog Bipe thread
shepard62 01-22-2012 05:47 PM
1 Attachment(s)
aymodeler- I am impressed so far with the quality of the kit . The photos in the instructions are clear and sharp and the laser cuts and fit is great.
I have not tried any odorless yet. Using titebond for now.
Seamus, I have read your thread many times and I admire your work. I am using my 40 cal boxes to weigh down the wing right now.
I even went out and got a hollow core door to use as a flat work table.
Bill
SeamusG 01-22-2012 06:19 PM
Bill - while your at it, replicate the I-struts. See if you can find some unused kit wood that can be used.
Have fun and post often! <br type="_moz"/>
shepard62 01-23-2012 06:18 AM
Seamus- Great idea, I will go to the LHS today and look for some 3/16" ply for those I struts.
After looking at your thread I have a question.
OK , how did you make that hatch cover ? BETTER than most ARF's . A work of art !!!
Can I buy one from you?<br type="_moz" />
SeamusG 01-23-2012 09:11 AM
1 Attachment(s)
I just look at everybody's planes - new, old, scratch, ARF/RTFs. Some have creative bits and pieces.
The SSE canopy / cockpit hatch is made with a former up front, a former at the front of the cockpit (dashboard) and a headrest. Between the front former and the dashboard they use several 1/8" stringers with the front and rear formers cut to accept them. I just did the same using a lite ply base, lite ply formers shaped to match the HB "shape", cut some stringer slots, added stringers and then sheeted with 1/16" balsa. Also reinforce the sides of the fuse. Add a couple of cleats to the bottom that position the hatch bottom between the reinforced sides. I used 1/16" dowel to pin the front of the hatch into to back of the firewall area. A couple of magnets at the back and it's all good.
And, no, you can't have mine!
pic 1 - tank hatch on an SSE
pic 2/3 - top and bottom of cockpit hatch of an SSE
shepard62 01-23-2012 05:07 PM
1 Attachment(s)
Moving along with the build , Balancing act between slow enough to build it right and fast enough to stay excited.
The clamps are there for the balsa to lean against so the sheet will have a flush fit with the leading edge stock.the blue tape holds it tight.
After the glue dries , a little water / amonia mixture to shape the balsa sheet to the ribs and TA-DA.
shepard62 01-24-2012 01:05 PM
1 Attachment(s)
The leading edge sheet went on nicely and the water/ amonia worked well. Good joints between ribs and sheet :) .
SeamusG 01-24-2012 02:05 PM
1 Attachment(s)
This post will seem totally out of context - oh, well - http://www.rcuniverse.com/forum/js/f.../msn/47_47.gif
I would free up the I-strut upper mount using an X-acto blade like pictured. You can use a tack hammer on it like a hammer-n-chisel. Light, light taps. Clean up the inside of the gap with the same tool. Clean up the sides of the upper mount with sand paper. Reglue and use spring clamps to keep it from creeping.
HTH
shepard62 01-24-2012 03:18 PM
1 Attachment(s)
Thanks Seamus-
This is what he was referring to :
The red pen shows a gap . The other photo shows the proper position.
To fix or not to fix , that is the question . I think because the piece is close to where it should be and glued in tight - move on.
Seamus ( a very talented and veteran builder ) suggested that I dig it out and move it.<br type="_moz" />
shepard62 02-18-2012 04:46 PM
1 Attachment(s)
The magnetic hatch over the fuel tank has kept me up at night concerned about how it would turn out well here it is. I was so worried that it would not be as good as SeamusG. And it might not be , but I am happy with this.
The last photo shows the two magnets held in place with very fine fiberglass cloth and a few drops of CA.<br type="_moz" />
Steveibrc 05-08-2012 04:44 AM
Don't know where you are now since it has been a while since you did an update......but it looks good so far!!!!!! Did you get the interplane mount issue straightened out? Steve
shepard62 05-08-2012 04:47 AM
1 Attachment(s)
Still need to fabricate a balsa headrest , but both wings are done .
Starting to cover certain parts.
Getting excited to finish and fly it !
Steveibrc 06-09-2012 04:38 PM
Looks really good! You said you finished the wings..........You must have got the interplane strut mount issue resolved. Just keep on swinmming-You will get her built!!
One thing you might consider on the balsa headrest. I used a soft easy to carve chunk of balsa then put a single layer of glass using polycrylic as a filler. Should have used two layers of glass there. Mine is very easy to dent. That is a wear area that my stand contacts and the headrest catches considerable abuse if i am not careful.
shepard62 06-10-2012 04:14 AM
Hey Steve, I have a Saito 100 all set for this bird. I saw some other hogs on here with holes so .....
As for the balsa headrest, thanks for the "glass " tip. Does 21st Century fabric go over fiberglass? Is the application the same as wood?
And I am sure all the builders will understand this: I have a vacation coming up in July and the entire focus will be completion of the Hog! (talk about not having a life !)
Steveibrc 06-11-2012 02:49 PM
The fabric will do fine going over the glass, will not make any difference on the application.....Just iron away!
Steveibrc 08-26-2012 08:40 PM
What's up?????:) Saw you posted some pics over on the hog thread.......You are coming along great! Won't be long before you are flying that machine. I have run about 1 1/2 gal of fuel through mine so far..It flys like a dream once i got a handle on it charastics and got the gear moved forward. Slung thge hatch off the other day doing a snap roll, but that was my fault. I had taken the tank out to test fit the tank style in a PCA-2 autogyro i am building, and when i put it back in the hog i didn't cinch it down tight enough and it shifted enough to pop the magnets aloose. Miracle we found ity in waist high sweet potatoes:) Check out the build thread on RCG when you get a chance.....It is under: Special Interest-Autogyros-2012 PCA-3 by Steve Keep me informed on your progress and give me a hollar if you need some help on a bit of brainstorming......Later, Steve
shepard62 09-01-2012 07:24 PM
1 Attachment(s)
FINISHED !!!! 9 months of working on it . Now it's time to pick a day for the maiden.
Smashmaster 09-02-2012 05:05 AM
Nice job. If you pick a day for the maiden though,we all know it will be a windy SOB that day:D
Fred
r2champion 09-17-2012 09:30 PM
Quote:
ORIGINAL: shepard62
Great looking Hog! You will love it, as I reminded myself how much I love mine this weekend.
I have been overly busy the last couple years and unfortunately flying had to take a back seat. I've had the itch all summer to fly again, so this weekend I took the hog up to the field along with another plane. When I started assembling the hog, I realized I had left the inter-wing aileron connectors behind.......DANG! I wanted to fly it so bad. I flew my other plane a couple times but I NEEDED to fly my hog! (Light bulb went off!) I grabbed the packing tape out of my flight box, and secured the top ailerons flush with the top wing, now I had bottom ailerons only. I knew I could fly it with rudder only if the bottom ailerons weren't providing enough authority. I gritted my teeth and off she went into the most beautiful ascent I've ever seen with that 4-stroke purring away. This truly was the flight I needed to get back to flying again, my knees were weak as water I was enjoying it so much. It was a bit lazier with aileron control, but flew just as well as if I had top and bottom ailerons functioning. I came in for the best landing of my life, smooth, flawless, and straddling the center line (I owe that to the hog, not my abilities). My hog renewed my priorities with one single flight, man I love that plane! Hope you have (had) a great maiden flight with yours!
tacx 09-19-2012 04:01 AM
1 Attachment(s)
Shepard62,
I'm glad I'm not the only one who broke off those tabs !! LOL. Other than that the kit was a pleasure to build. I may use the plans and built another this winter. I was concerned about how differently it would fly from a single wing, but I was pleasantly surprised at how well it handled. Let us know how your maiden goes.
Here are some pics of mine.
JollyPopper 09-19-2012 06:04 PM
tacx, what is your hog covered with? Beautiful job whatever it is.
tacx 09-22-2012 02:45 PM
Thank you,
It is my first plane covered with Ultrcote. I have used Monokote exclusivly up to this project, and thought I would give the Ultra a shot. I really like it. I never had much trouble with Mono, as some people have indicated, but I found the Ultra easier to work with. It requiers less heat and shrinks very well. It isn't as shiny as Mono but still looks great.
