RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Nose or tail heavy?? (https://www.rcuniverse.com/forum/kit-building-121/1949829-nose-tail-heavy.html)
a68fan 06-30-2004 03:58 PM
Still building on my 4*60...
Question..... If built as instructed, with a MDS 65, standard radio gear, will it come out nose or tail heavy???
Thanks!!
leftnut 06-30-2004 04:11 PM
RE: Nose or tail heavy??
neither.. it depends where you mount the servo plate
RX , battery pack ,tail wheel set up and what size tank.
a68fan 06-30-2004 04:57 PM
I want to determine How far forward, or aft to place the servo tray, etc...
Chuckr53-RCU 06-30-2004 07:24 PM
Just my $.02...build to plans. You should be able to manage the CG with placement of the battery pack & the receiver. Your engine is about the same weight as an OS61FX which the plane is designed for.
Edwin 07-01-2004 07:30 AM
Its not difficult to check your balance as you build. Once the basic structure is built, set it on the balancer and start placing equipment until it balanced where you want it. 1200ma nicad battery packs are good for fine tuning the CG.
Edwin
MinnFlyer 07-01-2004 09:08 AM
You can also glue hardwood rails to the sides of the fuse, so you can slide the servos fore and aft. Once you find a good spot for them, either glue or screw the servo board to the rails.
leftnut 07-01-2004 01:21 PM
i mounted the plate in the middle to allow placement for the
battery pack in aft or front of the plate.
i ended up placing the battery pack in the fuel tank area.lol
but was able to move the pack back as i got more comfortable
with the plane.
