Kyosho Helicopters Discuss all Kyosho heli topics here.
kyosho caliber 30 help
Reply
Old 12-21-2006, 12:43 AM
zepish
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default kyosho caliber 30 help
hey guys.. i just bought a used kyosho caliber 30 heli.. i started it works fine. but the rear blade dident spin so i looked to see if i could find the problem and the belt was loose so i tried losening it up and ajusted it. ok so it all looked good but when i tried to start it again with the starter, the motor wont turn anymore and i really dont want to damage it.. any ideas on what it can be.. i called a hobby shop but they cant fix it for another 2 weeks and i really want to fly it..
zepish is offline
Old 12-21-2006, 02:33 AM
helityro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: kyosho caliber 30 help
Hmmm. Could simply be flooded.Take plug out,turn over again with starter then replace plug.Does the starter strain? If its turning but your motor isnt it could have spat out the capscrews holding the fan on.Engine shaft might have unwound and now jammed the fan against the shroud if its locked solid. Check the tailbelt pulleys are tight and grubscrewed on to make sure you have drive to the tail...........Have fun.
helityro is offline
Old 12-21-2006, 08:55 AM
Cyberfyn
Cyberfyn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It does sound like it's flooded. As Helityro says take the plug out and tip it forward (also helps to turn it over a few times to blow any excess fuel out)
Or you may have over tightend the tail belt. It should compress about half its width before it enters the tail (squeeze it with your fingers or a pair of long nosed pliers)
As for the tail, turn the tail blades by hand. Does the belt turn at the engine end? If not something is loose at the tail end. Just be methodical and track it down. You shouldn't be flying one of these if you can't fix simple and obvious things. Not flaming you, but every second hand heli I've had has had a FULL nuts and bolts strip and re-build, Just to make sure it's air worthy. All helis require a LOT more maitenance than fixed wing models and need a LOT more respect
Did you get the manual with the heli? It has a detailed strip and re-build section telling how to repair the rotor head or tail rotor. It can be downloaded from Kyosho directly if you dont.
Let us know how you get on and we'll try and help.
Ian F.
Cyberfyn is offline
Old 12-21-2006, 12:04 PM
zepish
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
. no manual but i found one online for it and ive read it threw.. ill test it out inabit.. thanx for all the help. ill update.
zepish is offline
Old 12-21-2006, 01:26 PM
zepish
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok well i took the plug out and tried to turn it yet with no luck.. the motor will not turn.. im at a loss.
zepish is offline
Old 12-21-2006, 03:13 PM
helityro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey zepish,your going to have to pull things apart.My cal3 broke its clutch shoe and locked like yours.Trust me,it doesnt take long and isnt that difficult if you refer to the manual.Good luck.
helityro is offline
Old 12-21-2006, 04:22 PM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check the fan, the chances are you tried to start a flooded engine and the fan spun off.
BarracudaHockey is offline
Old 12-22-2006, 06:54 AM
Cyberfyn
Cyberfyn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah teh fan once spun off on mine as well. Red locktite sorted that little problem out
Hey Cuda, what's the weather like over there? I'm on my way over on Boxing Day.
It got down to 5 below here last night
Ian F.[&:]
Cyberfyn is offline
Old 12-22-2006, 03:02 PM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Crappy this weekend and Christmas, mid 70's F but rainy.
Up north they just had a few feet of snow.
