Tempetature on a OS50 hyper
RE: Tempetature on a OS50 hyper
Look for around 180-200F (in flight if possible). Although you can check the temp if you can land quickly enough.
Ian F.
Ian F.
No. I have a Venom that has a sensor bolted to the head. But if using an infra-red or laser heat gun, the plug is the best place to get an acurate reading from.
Ian F.
Ian F.
My Feedback: (193)
FL
If you can reach under there and put your finger on the backplate for a few seconds without feeling like you are getting burned, it's about right. It will be very warm, but not too hot to touch. My temp gauge tells me 160 or so. --Tony
