JR 7202 Programming for Nexus .30
Hi guys
I'm having trouble Programming my JR 7202 to one of my Nexus .30's
I Have the Channel,modulation,Freq,and servo's in there but It's not right
The only time I can get the Swash Level is at 1/2 Throttle
when I raise the Throttle or lower it the Swash tips back and forth
This is what's not right
I've tried to switch the Swash Type and adjust the Sub Trim and it's still Not Right
The swash shouldn't tip when Moving the Throttle and I'm at a Loss as what to do now
I have been Messing with the Settings for Days and Can't figure this out and the Manual is not Helping me figure this out
Please HELP
Rich D......
Please HELP
Rich D......
NJ
RE: JR 7202 Programming for Nexus .30
ok first off set the swash to standard 1 servo, second: the swash should be level at left stick's center, with 0 degrees of pitch on the blades. Start there.
OK I got all that straightened out
the Tail servo is still fluttering Like Mad
The Gyro is an old 501 with a 9253 Digital Servo
I tried to change the frame rate setting, from high to norm and it's still fluttering like Mad
I even tried to set up another Heli into the JR 7202 Tx. and the other heli has a GY 401 on it, and it too is fluttering
and the led on the 401 is blinking and it won't initalize at all
do you guys have any suggestions ???[:@]
NJ
sounds like A: you used trim to center it, B: your initializing in Rate mode which wont work. C: Your gain is way out of whack. BTW, do you have the gyro set to digital servo (DS on the Gyro)
I didn't use any trim at all
How do I tell if it's in Rate Mode ??
as Far as I can tell the Gain is at Zero
How do I tell if it's set for a Digital Mode
I'm not messing around
I've never Programmed a Tx Before this
and it's a Real Mystery top me as to what the Hell is going on
I would appreciate any help you can Give me at this point
Rich D
Rich D
NJ
I have no experience setting up a 501 although if i had it here i probably could.
http://www.roboticunicycle.info/docu...501-manual.pdf
Hey barracudahockey you think you could help me here?
I don't think it's the 501 I think somethins up with the JR 7202 I tried to put another Heli in to it and It's doing the Same thing
The other Heli Has a 401 and the LED'S Blinking and it won't initalize and the Tail servo is doing the Same thing
Thanks for the Link
GP
Thanks for the Link
GP
NJ
ok its blinking either A: it's not in heading hold when you power up, or B: you hit the rudder trim in heading hold and it is reading that as a command.
on the 7202, go to channel assignments section, set Gear to Gear.
this will be your switch for rate mode to heading hold.
Plug the single wire plug from the GY401 into GEAR on the reciever, the other lead goes to rudder. set the ATV's on the gear channel to control your gain, the ATV's on rudder should be set to Left 85% right 110% thats just a baseline for pirouette rate, adjust to your liking later.
try this and then we'll go through tail setup later. lemme kn ow how it works
