Kyosho Helicopters Discuss all Kyosho heli topics here.
repared
Old 07-18-2003, 10:20 PM
aerodynamic18
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default repared
just to let u guys know i replaced my main shaft of my heli and also replaced the plastic mixing arms with metal ones(they are blue ) so i will test fly it fomorrow. also does anyone have any tips on the best way to get the slide block in the right position so that the bars can slide through it cause at the min i can get it ligned up but the bars stick in it
aerodynamic18 is offline
Old 07-19-2003, 05:31 PM
randy41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default repared
Position the side block collar 13.5 mm from bottom of
center hub to top of side block collar. Slightly tighten(should be able to still move it). Move the side block pins up in the side block
collar. May have to rotate side block collar one way or the other to
align the side block pins with side block collar. Remeasure and then finish tightening.
randy41 is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
