help with pitch setup for caliber 30
hey all, i was just wondering what your pitch settings are for the caliber30 with a OS 32SXH and wildcat heli-mix 15% at both mid stick(hover) and at top stick? any help would be great[8D]
RE: pitch
Hi,
I have mine set for 5.5 Deg for hover and 9 Deg. for full stick. |
RE: pitch
1 Attachment(s)
pic of caliber. I have the quick uk metal swash plate, mixing arms and head button all in blue. Also i have the tail boom in silver with the fins painted the same blue as the quick uk blue to make it different. Also have a heading hold gyo which is great.:D
RE: pitch
Have fun.
Pitch Curves P-NR: 1 2 3 4 5 Degrees -3 -1.5 0 +5 +8 % 32 40 45 68 80 T-NR: 1 2 3 4 5 % 0 17 30 75 100 P-I1: 1 2 3 4 5 Degrees -8 -5 0 +5 +8 % 8 22 45 68 80 T-I1 1 2 3 4 5 % 100 75 30 75 100 P-I2: 1 2 3 4 5 Degrees -8 -5 0 +5 +8 % 8 22 45 68 80 T-I2: 1 2 3 4 5 % 100 75 30 75 100 P-HD: 1 2 3 4 5 Degrees -6 -3 0 +7 +11? % 20 32 45 73 100 HOLD: 1 % 70 Keep them blades turning ! |
RE: help with pitch setup for caliber 30
Mid stick zero degrees, full stick 10 degrees, minus is 10 neg. I fly my Caliber with the V curve, lift off and landing I switch to normal the pitch curve stays the same.
does this sound ok
midstick 5.5 degrees with 50% thottle highpower 9 degrees with 100% throttle this i for everyday flying with no stunt(so far;)) as i am still praticing nose in and have decided not to do any stunts till this is done. |
1 Attachment(s)
Heres my pic
Piss on it. get a govenor and let the damn thing rip.:D
