will this be a problem?
1 Attachment(s)
this is a "new in box" caliber 30 i bought here on rcu. looks like heat damage where the gyro will sit. because the area is deformed, will this be a problem?
RE: will this be a problem?
I think it will be fine, just make sure the gyro is on the level area.
Ross |
1 Attachment(s)
that's what i'm mostly concerned about, there is no level surface. it's concaved in the middle.
It only seems to be damega on the left side. Can you buy a new servo holder box thing....
it's moulded into the frame, i would have to replace the whole airframe. most of the damage is on the left but has affected the right side.
If thats "new in box" then I'm next inline for the vice presidency.
I think things should be stated as things are.
http://www.trademe.co.nz/Toys-models...n-69891096.htm Look at that listing (I did that). Everything is stated as is. People that "bend the truth" just make it harder to buy things online and get things that we may really need. |
after speaking with the seller, he ordered the parts needed to fix the airframe. thank you for your input.
Now that is good help. You should give him better feedback (if there is a thing like that).
