Darth's Heli Bodies
IL
RE: Darth's Heli Bodies
Hey FF,
Your fuse looks SWEEEEET! Any major problems fitting it to the crutch (brackets, mounting points, clearances)? Could you post the link for Darth's Heli Bodies?
Beaner
Beaner
My Feedback: (17)
Darths webpage is at http://darthdrk.4t.com/index.html their are lots of other fuselages to choose from for your corona. I had no problems mounting the fuselage, I used a threaded rod right through the metal crutch to hold both sides of the front half of the fuselage on, then I bolt the tail section on to the front half of the fuselage.
Probably one of the nicest paint scheme Ive seen on the 206 Jet Ranger. You did a nice job on this.
Just need the scale like tail feathers now.
