Trex head on 110-117
AZ
RE: Trex head on 110-117
I don't think it would be worth it but i gues because you are running the gas setup it is defenitly possible.
You will need
The head
New main shaft
Drill everything to fit the main shaft (crown, main gear)
And those plastic things with bearings that hold the mainshaft to the heli.
You will probabley also want a one way bearing for autos
If you can do it for around 100 i say go for it.
Good Luck
You will need
The head
New main shaft
Good Luck
