what nitro % and plug are u running in XXL?
okay guys, i should be making the plunge this weekend if time permits. (buying xxl)
ive been reading, studying, watching . nitro break in, sealing,etc videos and posts for weeks now.lol. it will probably take me a month or so of tinkering before i actually drive it. lol. im going to seal the engine, and loctite the screws etc. (it probably helps, its colder than s%#@ right now in michigan anyway)
SOOOOO.
1. what kind/brand of nitro are you running in the xxl/your trucks.? and what percent nitro?
2. what kind/brand glo plug are you running in the xxl, and hot,, cold , medium etc.
is this stuff anygood? (which one should i get also) http://www.odonnellracing.com/
im starting to get the picture how, nitro percent, affects compression, heat etc.
so the higher the nitro content the colder the plug should be?then engine shimming comes into play?
basically i want to run in the safe zone since its my first nitro rc. i want to be able to tune it also. the truck will be used for bashing.
thanks for the help
SOOOOO.
thanks for the help
NY
RE: what nitro % and plug are u running in XXL?
I use 20% and 30% byron fuel mixed 50-50. I believe it also comes in 25%, but not where I live. I also run O'donnell #99 plugs now, I was running OS #8 plugs before. I like the #99, it makes more power and idles better. I'm unsure about the longevity of the #99 plugs though, you may want to get some of each.
The fuel you linked is a bit lower oil content than I would use, but it must be good for something......probably hardcore race engines.I would look for 10-12% oil at the most. Anything more will cause trouble.
oops i was actually just trying to link to the manuf. page.....
their T BLEND is 10% oil
and their RTR is 12% oil
so i could use either of those with a medium heat range plug?
ill probably get some of each to try out.. (odonnel, os etc)
just to make sure im right, the less oil content the more "power", running leaner etc.....
NY
Less oil means cleaner, cooler, safer running. Too much oil can actually lead to over-leaning the engine, because of all the smoke and cruddy oil that tries to burn at 30,000 rpm. The r2r looks good, it must be new. I used to use their 14% oil, 20% nitro'race blend' fuel and it was decent stuff.
I run %25 and firmly believe that the OS A5 will get the most performance from a Losi 454 - or any of the SH engines - Mach, Big Red, LRP, etc.. For break-in use a hotter plug - like what it comes with, or an OS #8..
The A5 btw has been renamed the #10.. FYI...
Non LC numbered OS plugs are not long reach plugs. They will work, but not as ideal as a long plug. Idle and transition to wot will be better with long reach plugs. Depending on mixture, you may or may not notice. I just find so many people use OS plugs and they aren't the right plug to use in most engines because of the shorter reach. The last 2 OS plugs I used was a #5 and #8 and they were so short. Use what you like.
I have had good luck with McCoy #59 hot plugs, but odonnell are good too. I use #59's from 0% nitro up to 25%. Higher than 25% I'd use a medium long reach plug. I forget the number off hand.
For off the shelf fuel, I like 25% nitro byrons, or 20% nitro blue thunder race. Byrons smells different than most other fuels I've used (exhaust is what smells different.)
I've heard about the different-length plugs thing, but I seriously doubt it makes a difference. I've used McCoy and Odonnel and LRP and Novarossi I think, but still, for these SH engines, the OS A5 just gives the best top-end performance.. True though, idle is a bit less constant, so you have to blip the throttle more to keep things cleared, but for all out performance, for me the OS A5 is best... Temps are cool too...
ok so we need to use LONG plugs in the 454 motor?
so if you are using a nitro 20% with 12% oil/caster such as this http://www.odonnellracing.com/tblendfuel/index.html
you should be using a hot plug? or medium?
i understand that individual motors, fuel type, etc. make a difference but is it true, roughly that 20% nitro and under use hot/medium plugs,. any above that use cold plugs?
oh btw.... im not trying to push the motor to its max just yet, (i.e. running max nitro %) i just want to get the hang of tuning etc...
ORIGINAL: c.rod
MA
Before you start swapping out plugs etc. stick with the stock one for now, get to know ur truck FIRST before making any changes. Use a good fuel like Byron's 20% or O'Donnell.
ok. this is the fuel i got. http://www.odonnellracing.com/racingfuel/index.html
all they had locally , guru hobby guy, said it should be easier to tune due to the 8% oil ratio, but make sure i dont run it to lean..
also i got http://www.osengines.com/accys/glowplugs.html
the LC3 hot,
the LC4 medium. both are long reach,
ill try the stock plug for starters on break in etc. but i fig it would be nice to see the diff. in a medium and hot plug once i get going... but seems like with 20% fuel its ok to use a hot plug,
the LC3 hot,
ORIGINAL: c.rod
the LC3 hot,
the LC3 hot,
Engines cope with extra oil far better than too little. If you decide to go with the 8% anyway, I'd add 2-3oz of castor oil to a gallon of fuel for extra insurance. Castor oil has a superior ability to protect the engine in the event of a lean run. Some will argue the extra oil point, but to those I would suggest asking around in the glow engines forum towards the bottom of the RCU main forum page.
During combustion, most of your synthetic oil will burn therefore reducing lubrication of the engine. This is where the extra castor shines because it burns about 200 degrees higher than the synthetics thus giving you better lubrication. I do not think typical blends have enough castor oil. (typical 80/20 blends only have 2.4% castor from a 12% overall oil content)
This is just my opinion.
MA
Is the O Donnell fuel only 8%? I use that for my racing .21's but I use Traxxas top fuel for break-in and my bashing rollers, I know its 16%. Its good stuff and its pretty cheap too.
ok im take the race stuff back for now, im gonna run straight caster % for break in. i got some of this. which shouldi use for break in?
http://www3.towerhobbies.com/cgi-bin...?&I=LXAJP0&P=0
http://www3.towerhobbies.com/cgi-bin...?&I=LXBBS7&P=0
12% or 16% caster
12% or 16% caster
ORIGINAL: c.rod
12% or 16% caster
12% or 16% caster
NY
I would get fuel with 10-12% oil and run it as rich as possible while maintaininga goodtemp and running characteristics....even if you have to wrap the head with something to keep it up around 200. The extra fuel and oil comingthroughhelps flush out the microscopic particles that wear off during those first couple tanks. Castor oil really works it's magic in the higher temperatures, that's why having a syn/castor blend is best.
ORIGINAL: Mclovin350z
I would get fuel with 10-12% oil and run it as rich as possible while maintaining a good temp and running characteristics....even if you have to wrap the head with something to keep it up around 200. The extra fuel and oil coming through helps flush out the microscopic particles that wear off during those first couple tanks. Castor oil really works it's magic in the higher temperatures, that's why having a syn/castor blend is best.
Here's some tapered-bore break-in info some may get something from. This is written around aircraft engines, but the principles are the same. (oil content is obviously different in car engines but I'd still use an extra 5% oil for break-in in a car engine)
http://www.rcuniverse.com/forum/m_1850473/tm.htm
Its more-or-less a type of heat cycling though those guys run their engines for a longer time at a stretch than I do. I run mine for about 5 minutes at a time before cooling it down.
My Feedback: (-1)
There's a huge amount of info in this link. There was a few of us that had bought one when it first came out. The first 3-4 pages aren't much. . . . .then about page 5-6 it gets interesting. Take some time this weekend and read up. You'll learn a ton. I was one that had recorded a 52 MPH run with my XXL. I Had a picture of it somewhere and it was posted again a few times but not sure where. Good luck to ya. Oh, I ran Byrons 20% in all my nitro trucks and ran an O'donnells plug.
http://www.rcuniverse.com/forum/m_85..._1/key_/tm.htm
[youtube]http://www.youtube.com/watch?v=rhFpmd4IbOQ[/youtube]
[youtube]http://www.youtube.com/watch?v=e2Z2iQIlhj8[/youtube]
[youtube]http://www.youtube.com/watch?v=xm6QA7yVB_8[/youtube]
looks awesome... ive seen those vids before...lol. didnt know it was you. lol. im gonna seal my motor tonight. check some kit screws. (a lot of them were loose that i randomnly checked.....
hopefully start it for the first time on mon. when my fuel comes in from tower hobbies... no one has crap for fuel in MI right now. just race stuff or traxxas....lol. nothing that might be considered "break in"fuel with a little higher oil content....
MI
Blue thunder sport fuel 20% Seems to hold a tune nicly. I also like trinity monster fuel.
mccoy mc59, a5 for glow plugs.
