DX3S Telemetry question..
I know the Telemetry isnt the most accurate, but I thought for S&G's to put the sensors on. Does anyone know if the sensors that come in the DX3S radio kit are the same exact parts as what comes on the XXL? The sensors that came in my kit dont have long enough wires to run from the engine to the radio box. Are there extensions that can be had or....?
Engine is an SH .28 P6 w/ losi flywheel & clutch.
RE: DX3S Telemetry question..
just grab some 6 inch servo extension wires. the lhs will carry them most likely. good luck with the rpm sensor[:@][:@][:@]
ORIGINAL: steed2
Anyone got a pic of their RPM sensor mounted on a stock XXL/454?
ORIGINAL: Mclovin350z
I think it's just a speed sensor, located on the front drive shaft.
I just assumed they used a different flywheel on the 454 to accommodate for the RPM sensor.
ORIGINAL: impalapolicepack
rpm sensor is on the axle.
NY
I took all that crap out of my xxl. The temp kept beeping at me when it reached 237, which was more like 220, and the rpm never worked when it was new.
On a different note that I am concerned with... When I installed the two receivers (one SR3300T telemetry Rx and the SR300 Sport Rx) I noticed the antenna wires are really short. I know most of them come that way, so when I installed the receivers in (both LST2's) the stock radio boxes I put the receivers as close to the antenna wire hole as I could and held them in place with velcro. I ran the wire through the hole and cut an antenna straw down to be just shorter than the wire is long so I could fold the end of the antenna over the top of the straw and put a rubber antenna cap on it. It looked neat and compact, but I ran into several instances where I would hit the throttle and nothing would happen with the truck at about 50 yards away. This was on pavement. I ran it through a soccer field and had the truck roughly 75 yards away and it responded well from what I could tell. (I couldn't hear the engine at all in the grass as this distance) I did try running the truck without the rubber cap on and the wire sticking straight up but still the problem persisted. At any distance shorter than say 50 yards it responded fine. I also noticed that when the throttle wouldnt respond on the truck, the receiver did not go into failsafe mode (full brakes) so I am a little stumped. If it lost a connection, it should have tripped and set the brakes which it didnt do. I installed and setup the radio according to conventional wisdom, however I'm not real familiar with the "quirks" of the 2.4GHz radios.
Any thoughts on this? I rarely find the need to ask questions with these trucks I just dont ever have any problems with them.
NY
Hmmm. I really don't have a clue there. All my trx systems have long antenna wires, but only about 2 inches are in a tube and I can go almost 1/4 mile no problem. Haven't ever looked at the xxl radio sytem, I just run it as is.
It's in a tube about 2'' long, not sure how long the wire really is though.
MA
Telemetry is actually relatively accurate and more importantly its very consistent. With the rpm monitor you dont want to mount that to the driveshafts like they do on the LST. The pickup sticker will fly right off, better mounting it direct to the engine motormount / flywheel assembly. The temp sensor you need to make sure its mounted the the LOWEST FIN on the heatsink. The battery voltage obviously is incorperated into the rx. And they make plenty of extension wires for rx's etc.
ORIGINAL: ntrain42
I could probably make something to fit, but I dont have a tap that small. Those screws have to be 2-56 or thereabouts.
MA
ORIGINAL: 1QwkSport2.5r
The only problem with mounting the RPM sensor in either of my LST2 trucks is the fact the losi flywheels are too small in diameter to get the sticker onto and get the sensor close enough. I would have to change flywheels in order to mount the sensor on the motor mounts.
ORIGINAL: ntrain42
Telemetry is actually relatively accurate and more importantly its very consistent. With the rpm monitor you dont want to mount that to the driveshafts like they do on the LST. The pickup sticker will fly right off, better mounting it direct to the engine motormount /flywheel assembly. The temp sensor you need to make sure its mounted the the LOWEST FIN on the heatsink. The battery voltage obviously is incorperated into the rx. And they make plenty of extension wires for rx's etc.
ORIGINAL: ntrain42
Might want to look it over again, I could get my rpm sensor to the flywheel with the sticker without any real modification done. You have both the long and short sensor arm right?
ORIGINAL: ntrain42
just for giggles when I was bored the other night I stuck my eagle tree in my XXL and was amazed to find the telementry speed was almost spot on with the gps speed, might have been a fluke, but it sure showed me that it's very accurate when all your settings are done right.
