Losi Monster Trucks Discuss all Losi Monster Trucks (i.e. LST) in this forum. Optionally you may discuss this and all other MT's in our general MT forum.
Lst Elec. conversion
Reply
Old 01-16-2012, 04:10 PM
futureboy1969
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Lst Elec. conversion
Hey guys. I just picked up used LST to do an Eletric Conversion.. I tore it all down and did a nice clean up. I have the Mamba Monster combo ready and wait n for her...just need to order the Losi conver. kit...just like to hear from anyone who did one.....
futureboy1969 is offline
Old 01-17-2012, 07:41 PM
ImpalaPolicePack
ImpalaPolicePack's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Lst Elec. conversion
the losi kit is crap, but The Dude parts are expensive.
i made my own motor mount with a 3$ 1/4'' alum angle, and a 20$ Rc-Monster battery tray. (you will also need the simple speed hud from losi about 20$)
ImpalaPolicePack is offline
Old 01-18-2012, 04:30 PM
Orcatkt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Iused the Losi kit in mine. Everything worked just fine, Iam sure there are better quality units but this one works as good as any. With some throttle control there isnt even a wheelie problem with the weight distribution. Iran mine on 2* 2s packs and it was great, sold it recently to buy a new project.
There is a thread on here with pictures of how mine went.
Orcatkt is offline
Old 01-20-2012, 06:58 PM
Maj_Overdrive
Maj_Overdrive's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Losi kit has its limitations. Gearing being the biggest limitation, you're basically stuck with the 25T pinion they give you and the 63T 2nd gear spur. The mount can't get any closer to the trans without hitting it, and you'd have to open up the holes in the chassis to get it much further away. If you run the 2200kv combo on 4s you should be ok though, higher voltages I'd recommend a lower kv or a different mount for more gearing options. The batteries being out back makes the truck wheely alot in my opinion and I have pretty good throttle control. Thats fairly easy to fix though, just cut the tray down and mount it up front like I did. FYI I bought my truck already converted and it was too good of a deal to pass up so I made the kit work for me. It also already had the single speed hub, which is needed to get rid of the brake servo and mount the battery tray up front. But the single speed isn't included in the conversion kit. If I was going to do another truck, I'd go with either The Dude Mount or make my own, Losi single speed hub (The Dudes hub is pretty but u can't see it with a gear cover on it) and a RC-Monster battery tray.
Here's my truck: Losi kit, Losi hub, cc1520, 5s, 25/63, ~45mph
Inspiration for a homemade mount
Maj_Overdrive is offline
Old 03-28-2012, 04:29 PM
mechanike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey maj.overdrive is that a clutchbell for a brushless? who sells that?thnx
mechanike is offline
Old 03-28-2012, 06:35 PM
Maj_Overdrive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IDK much about the last pic I posted, something I found on a forum. The clutchbell appears to be a standard 2 speed nitro clutch bell with a Tekno Elektroclutch adapter. RC-Monster also sells a 2 speed pinion adapter.
Old 03-29-2012, 04:51 AM
mechanike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah i got a lst-2 roller coming for $130 shipped i will convert. i always wanted a cluch on a brushless.the ofna is too jerky without it.did not know it was posssible thanks!!
Old 04-30-2012, 08:03 AM
mechanike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah just got done with conversion.veh.came without any swaybars.should i get both or is only the front needed
Old 05-03-2012, 04:55 PM
devious1
My Feedback: (15)
devious1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All depends on where your main running is going to be,
I mostly run street so i had sways all the way around
my last one hardly ever seen the street so i didn't bother with the sway bars...
If your going to do sways go all the way around...
P.S. Need some pics...
devious1 is offline
Old 05-03-2012, 05:22 PM
mechanike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks.seems great on the street,,,,,,,,,,i'll try a pick file might be too big.i try downloading a pic twice both times it says succesful but nothing appears.maybe i'm blocked cause i have not ben here long enough,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 05-06-2012, 10:24 AM
mechanike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey maj.overdrive what are you using for brakes? you have a clutch so can't use the motor.servo is gone for the disc brakes,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 05-06-2012, 08:56 PM
Maj_Overdrive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My truck is the 1st three pics I posted. The last pic is not mine and I do not know exact details, there may be a clutch, the clutchbell could be also be locked onto a custom adapter, IDK for sure. With a clutch you need to run mechanical brakes though. I have single speed hub with a pinion, no clutch so I'm using motor/esc brakes. Startup on sensorless brushless isn't always the smoothest, but once its rolling I don't have any issues. Brakes take a little getting used to and some tuning with max force and curves, but again IMO I don't see a need for mechanical brakes with brushless vehicles.
Old 05-07-2012, 05:30 AM
mechanike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanx maj.overdrive.
Old 05-25-2012, 02:59 AM
futureboy1969
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok... I'm back to say, that my E-lst is ONE of the most SWEETIEST tucks i have and the funniest!!! I post pic. asap!! the Losi coversion kit worked great and the single speed hub too..I bash and race my truck..Nothing bad to say about it...
Old 05-25-2012, 03:17 AM
mechanike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yessir i'm a big fan.two speed thats blistering fast,,,,,,,,,,,,,,,,,,have not topped it out yet.keep runnning out of room!
Old 05-25-2012, 07:10 AM
futureboy1969
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To each is own, bro...but my lst kit is solid!! here's a few pics. Well sorry . damn site won't upload the pix..i'll try later.
Old 05-25-2012, 03:57 PM
futureboy1969
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Uploading finaily worked!!....And YES I use the same body for my Nitro Lst...if ur wondering about the air holes..lol
ID:	1765829   Click image for larger version
ID:	1765830   Click image for larger version
ID:	1765831   Click image for larger version
ID:	1765832   Click image for larger version
Old 06-08-2012, 04:15 AM
digital1234
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is truck motor to big areal tyre for the  riding on the high mountains  and the  areal  of the tyre so  high  there is  chance of slip in the  stone  parts. truck ramps is the  Great post to know more  information about the   truck loading ramps   make it your link.
digital1234 is offline
Old 06-08-2012, 09:16 AM
Muskokarc
Muskokarc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok that did not make any sense.
Muskokarc is offline
Old 06-08-2012, 10:00 AM
mechanike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah its not at all your location its happening here also,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,trailerpark boys rule!!!!!
Old 06-13-2012, 05:22 PM
Maj_Overdrive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for posting up your truck, looks good! I don't mean to harp on mounting the battery up front, but it will lower the center of gravity improving handling and the weight up front seems to help handling overall. But if you're happy with it as is keep on truckin!
Old 10-04-2012, 06:40 PM
bugeyes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maj Overdrive, I like the idea of using Traxxas receiver box for the receiver, may I know what receiver do you use? lmk, thanks.
bugeyes is offline
Old 11-17-2012, 01:53 PM
mechanike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heres the 2 speed retained model with cyntrifical clutch,,,,,,,,,,,,,,,,,,
ID:	1821278   Click image for larger version
ID:	1821279   Click image for larger version
Contact Us Archive Advertising Cookie Policy
