If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
  1. #1
    Join Date
    Mar 2009
    mindoro, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    new steering servos
    just looking for a couple high torque servos that are a direct fit for the lst2. thanks again guys.
  2. #2
    Moderator Foxy's Avatar
    Join Date
    Mar 2005
    Kingston UK, but living in Athens, GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: new steering servos
    How much you want to spend?
    Down with the crew known to pump up the bass...
    We rock the joint at a cool, steady pace.
    Foxy
  3. #3
    Join Date
    Nov 2009
    Hampton, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Hitec 645MG were a direct drop in on the HD Chassis. I do know that there are two different chassis servo cut out sizes so you have to make sure what you're going to be putting in. I didn't pay the price on the sticker. If you're on eBay check gonitrohobbies, they have good prices on Hitec servos.
  4. #4
    Join Date
    Mar 2009
    mindoro, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    probably around 40 45, not really looking for high end stuff just bashing around. will look on ebay at that store. thanks for fast replies guys.
  5. #5
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    In that range, the 645 is ideal.
    Foxy
  6. #6
    1QwkSport2.5r's Avatar
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I use Hitec HS645MG servos in my lst2's. They barely fit but work well. You'll need the servo mount kit which comes with the servo horns that fit the hitec servos.
    GlowHead Brotherhood #3
    Real engines use glow plugs.
    R.i.P Jacob Wetterling #11 10/22/1989
  7. #7
    Join Date
    Mar 2009
    mindoro, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the servo mount kit, is it from losi or hitec.
  8. #8
    Join Date
    Sep 2005
    Irgendwo, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I thought you needed MGT servo horn adapters or whatever to run Hitec servos.... ??
    Back in the day the LST2 came with JR/Spektrum Z590's, and people would upgrade to JR 650's.. Which most people seemed to like. And now those servos are stock in the XXL. Which is why I just buy stock XXL servos and drop them in.. The same servo is the stock steering servo in the RTR Losi buggy and truggy I believe.. Been a while since I bought some, but I think you can get them for $25 or so each...
    Changing steering servos in a Losi MT is a royal PIA....
    Nitro > stamp collecting, watching grass grow, cleaning room, etc.. > electric.
  9. #9
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: thef@st1
    Sorry, its from Losi. LOSB4250 is the part number.
    ORIGINAL: HerrSavage
    They fit with some every so slight modifications. Yeah, you have to pull the whole front end apart to do this, but its worth it IMO. Some chassis plates have snug servo openings to fit the 645's, so some adjustments with a dremel might be needed (dull tooling from stamping I'd guess). Mine fit the chassis, but one of the bellcranks would hit the top of the servo. I just shaved a little material off the bellcrank and it cleared fine then. I didnt need to take much off to do it, either. If you dont modify the servo openings in the chassis plate (like me), you will probably have to take the top of the servo case off and install it in the truck in two pieces, dropping the "bottom" of the servo into the servo opening and putting the top of the servo case back on the servo. IOW, its not a perfect drop in, but to me its pretty minor. They would drop right in if the servo openings were a little bigger.
    I looked at JR 650's before I bought my first set of Hitecs, but my LHS sold them for the same price ($50 ea!) and said the 650 is an outdated servo and I think the 645 puts out a little more torque anyway. I think they're fantastic and a perfect match in an LST2.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
