My LST XXL shuts off when brakes are applied
GA
My truck starts up fine and idles fine. But when running and I apply the brakes the egine shuts off only when brakes are applied. HELP!
RE: My LST XXL shuts off when brakes are applied
Had this happen to me.
Remove the filter so you can see your carb. You can do this without having the truck on most likely. Turn on your power and apply the brakes. Does your linkage push your carb past the idle position when the brakes are applied? If so, that's what's causing it. Post a pic if you can.
GA
Thanks guys for info. But come to find out today it was only my low speed needle that needed adjusting. She running like a champ now.
