Not restarting after running
ON, CANADA
Ok got my LST up and running. Have figured out the tuning of the MACH 26 for the most part. It runs great and starts up easly when I first start my run. Just loving the whole thing.
Ok the but is my question. After running for a while and I manage to stall it out fliping it over and not getting to it in time as and example. My problem is getting it to start again. It sounds like its trying to fire up but not quite catches. If Ilet it cool right down and then try again it fires up. Or if I had not been running it long and manage to stall it out it will fire up right away. I use a onboard ignighter that gives a auditable sound letting me know if the plug is good or not. So other than one time the plug is in good shape just put a new medium plug in it.
Any ideas that you can thing of me checking?
RE: Not restarting after running
ORIGINAL: Muskokarc
Ok the but is my question. After running for a while and I manage to stall it out fliping it over and not getting to it in time as and example. My problem is getting it to start again. It sounds like its trying to fire up but not quite catches. If I let it cool right down and then try again it fires up. Or if I had not been running it long and manage to stall it out it will fire up right away. I use a onboard ignighter that gives a auditable sound letting me know if the plug is good or not. So other than one time the plug is in good shape just put a new medium plug in it.
It would be worth going over the fuel system, and it might help if you make the feed line to the carb a bit longer to buy you time when it lands upside down.
ON, CANADA
Ok will check the piston and liner over can they be replaced or would it be better just to save up and get a new motor?
ORIGINAL: Muskokarc
BUT if the engine runs fine and restarts well any other time hot or cold, chances are the fuel lines need attention.
I'm not sure if the piston and liner sets are still available or if a set for a Mach 427 will fit. If you pull the liner out, measure the OD of the liner and I can see if my spare 427 liner would fit. Also check the number of ports; the 427 is a 6 port and the M26SS is a 3 port.
ON, CANADA
Ok will check that out. I just did a tear down and clean up last month. the lines are clear of any obstructions. I also put in a new in-line filter the old one that came with it did nothing it did not have any filtering material in it so I had not been using it the got another filter off a friend.
