need to replace the clutch on my LST
http://www.amainhobbies.com/product_...-Clutch-System is this over kill ? i jus run my truck on and off road at high speeds so ... any tips links or advise would be appreciated .................
RE: need to replace the clutch on my LST
I use the stock clutch and long-life losi clutch shoes on both of my lst2's. Other than some clutch shoe maintenance every so often they work fine on and off road.
A racing clutch is a waste if you're not racing.
Unnecessary waste of money for another. The clutch is one of the - several - things on an LST2/XXL that is good right out of the box. That’s what makes the Losi MT's so good - they come with , pipe, clutch, engine starting system, tires, the stock gearing is good, and so on. There’s not much, if anything that really needs to be replaced the way there is on other brands.
