xxl2e slipper nut
xxl2e slipper nut
Hi all. I haven't posted here in a while. I wanted to buy the Xmaxx but my lhs talked me into the 2e. Can anyone re-motivate me on why the 2e might be a better truck? I'm having serious buyer's remorse.
On another note, I'm having a terrible time keeping the slipper nut tight. It just backs out too quickly. I tried adding a small nut on the end and I even lock-tited it but it's not working. Anyone know a fix?
Thank you.
Thank you.
Thank you.
Thank you.
some of the screws & nuts an make sure their tight.
Maybe apply some loc-tite on the threads.
But however,I did notice your gears,spur & pinion are not meshed right,theres too much space in between the gears,so
you better attend to that before you strip the gears!
I second the gear mesh. surprised the truck moves at all.
When you last loctite the did you immediately hammer on truck blue picture needs a little cure time before it sets
I always coat it good and let it set over night before reassembly especially when it comes to high moving parts chassis not so much.
This is not the first time I heard people having slipper nut backing issues...
Just like all RTR's ,they are mass produced an are basicly assembled just as fast ,you almost have to break them down an add loc-tite to
Had 2 good suggestions today.
The pads will wear quickly if it's slipping at all because of the insane torque. Someone suggested I tighten it all the way after each run. Kind of a catch 22 cause of the trade-off on damaging what the slipper is protecting.
Also we can try applying a little ca in front of the nut to keep it from backing.
ON, CANADA
LOL I did the exact same. Except I bought the LST without any persuasion, I did it on my own. The X-maxx seems to have a lot of issues for a being a first run. The ESC is complete garbage and I am not spending $1200 CDN on a truck that I have to but another ESC for. I will probably own one thought once they get everything figured out.
I run my slipper full tight on my converted lst2
I agree with letting the xmaxx get worked out Plus give time for the aftermarket to come up with some stuff.. in a year or so you can pick a used one up at a good price
