Official Shock/Oil thrread
TX
Here is where to share you shock and shock oil setups. Please share those as well as what you use the truck for as in bashing or racing. Mine is still using the stock springs and oil and I am looking for the ultimate bashing setup.
RE: Official Shock/Oil thrread
Mine is currently as it came out of the box but i plan on getting some threaded shock bodies and different rate springs to try out. Will probably stick to 30weight oil
TX
Those of you running the 40 wt oil, does the truck not bottom out noticeably better? Or is this something a spring change would help more?
FL
The heavier oil really only effects the return rate making it less bouncy. Heavier springs would help prevent bottoming out.
NJ
Threaded, shock bodies, hot racing titanium jet vent pistons, hot racing orange springs for racing and purple high lift springs for bashing. 35wt oil
YT, BOTSWANA
Threaded bodies.
white springs front/rear
polished pistons
polished shafts
25 wt oil front/rear (Losi brand)
polished pistons
polished shafts
OH
I am stock right now, 30wt oil, silver springs.
Thermal, first glad to see you back in here, I know there were words with people but you should be in here. How does this setup work for you, and do you race, that is what I was going to try, I think the truck is to stiff stock.
YT, BOTSWANA
Sorry, i should have been more specific. First off, DONT compare any settings to my shock setup if you havent modified the pistons. Mine were hanging up quite a bit in the new shock bodies, and a little bit in the stock bodies. I sanded the squared edge off the pistons, and then polished them with crocus paper. While i had them apart, i polished the shaft with Nevr' dull. I guess what im trying to say is, after mod's, the shocks are VERY VERY SMOOTH. Alot softer than they were previously. Yes, this is a setup for racing. Bige, i have not put the truck on the track since i set it up this way. I think its gonna be good. I'll take it to the track Sunday, and give it some laps. I was previously running black springs front, white springs rear, 25 wt oil, no shock mods, and the same shock bodies (threaded).
ORIGINAL: bige4375
WA
Right now my LHS track is set up for fast laps. It has a double just before a tabletop and my LST can hit the table top off the front jump. (Almost 6 feet high and 15 feet long) When she runs not even the lightning can keep up. Then the track has an interesting canyon that snakes around, slows you a little, but very interesting. Then up onto a quick double then a washboard section, then a 3 turn 90% section then it’s home for a 75' long strait. Now for you question? I wanted to get a little more front-end lift to make the back triple so I wanted to increase my front-end lift. I did this by just making the inner holes of the piston a little larger (drilled them out) and I also hand sanded the edges. I use 30wt and white springs. The rear is stock with 30wt and silvers. I also ran my front shock strait, meaning that on top I have them in the outside hole and on the bottom the inside hole. This helps get around the corners a little quicker and help in getting the truck strait for the jumps. My back is a little laid more. The upper shocks are outside and so it the lower. This helps to get the end around a little smoother. Just some ideas and this setup is working well on my track. I win or in the top 3 when I don't break.
YT, BOTSWANA
From the sound of it, you went softer up front? White springs are one pound lighter than stock, and polished pistons make it smoother. The larger piston hole makes the shock react faster. If you want more lift, you would have to use a hevier spring, or heavier oil. Or both. Basically if you slow down the action up front, you'll get the entire truck to lift higher up front. Rather than having the suspension soak it up. Go back to stock pistons, without the holes modified. Polish them to make them smooth. Then try a black spring up front, white in rear, and 30 wt oil. Thats the setup i had, and i could put the nose straight up on jumps.
ORIGINAL: boogerdan
SD
I have stock so far, I am looking into geting the threaded shock bodies and running diff oil setup for racing prolly 30 wt front and rear! Welcome back thermal!
WA
Wow, I thought you were asking for what was working for me. Boy was I wrong. Thanks, for letting me know what I already know.
By the way, (I really don’t think you care) but I did try the black up front, and the landing was a little stiff in the front. I wanted more response since I only have about 10 feet to bleed off speed for a 90% turn, the lighter springs allow the front to dig in a little harder. Maybe I am wrong! all I do is crash and hit walls when I race.
If I am over sensitive to your reply, then I apologize.
ORIGINAL: ThermalRD
ORIGINAL: boogerdan
