What next
FL
What next
You may have read my other post in that I ordered a New LST yesterday . Well I went on a spending spree and bought the following:
Nova Cooling head
Werk's 4 shoe Power Clutch w/ carbon shoes
Gear Cover
CVD boots
Aluminum Differential cases
Aluminum Front, Center, and Rear skid plates w/ bumpers
Tube Roll bar w/ brace
Wheelie bar
Venom Receiver hump pack and Fail safe
fuel, after run oil, glow plugs, glow ignitor, etc.
Is there anything else I should get for my LST? I was thinking about Road Rage tires w/velocity 6 rims. Any suggestions would be appreciated.
Nova Cooling head
Gear Cover
CVD boots
Wheelie bar
FL
RE: What next
No suggestions? This my first LST, hell my first Losi product. I want it to be the best experience. All I have run are Savages and 1/8 buggies. SOOOOO......Please any advice good or bad.
CA
RE: What next
ORIGINAL: e-normus
Regardless you should buy some spare drivetrain components as these are what break and will leave you out of commision like cvd rebuild kits,a couple axles and cvd's,maybe spring for the MIP CVD's as I hear they're less likely to break.Maybe after I have my coffee something else might pop up out of the fog.
hope this helps
TX
RE: What next
If you want to buy tires for the street......
[link=http://www.hobbypeople.net/gallery/145535.asp]These and a set of LOSI LST sway bars...[/link]
I know the way mine corners on pavement with the sway bars and XTM Pento's with BRT1's and it is impressive, I just can't imagine what those would be like!!
