2nd gear shift point
CA
I have the 2 speed clutch shoes set at ONLY 2.5 turns out! The truck shifts at approx. 30-35 ft this is where I want it shift. If I take out the screw past 3.5 turns the 2 speedshifts almost immediatly....is anybody running the shoes this tight. This is a new truck I dont know the serilal number...where is it? also maybe losi has changed the springs?
RE: 2nd gear shift point
try turning the screws back to stock wich is 5 turns out from tight. mine were stripped when i got my truck causing it not to shift hope this helps
